Old 08-05-2007, 05:37 PM   #1
SLEEPERracer
SLEEPERracer is an unknown quantity at this point
Tanabe Sustec Pillow Camber Arm
anybody have experience with these. trying to get my tires to last longer. also if theres anywhere else selling them cheaper lmk. so far ive found this
http://intensepower.com/tasupicaarm2.html.
this is the cheapest ive found with the arm, usually i see companies just selling the ruca and its already more than this set i found. thanks!
SLEEPERracer is offline   Reply With Quote
Old 08-06-2007, 01:07 AM   #2
nism014
nism014 is an unknown quantity at this point
thats not a set. In the picture displayed on that site. The ruca on the right is for 89 to 94 and the ruca on the left is for 95 and up.
Tanabe is a very good brand, its battle tested and proven.
nism014 is offline   Reply With Quote
Old 08-06-2007, 03:40 AM   #3
SLEEPERracer
my car is pretty slammed. to adjust the camber fully would i need to adjust the toe arms too or would just getting the ruca be fine. somebody's just selling the ruca (for s13) silk road ones. if thats the case il just pick those up. any other info. would be appriciated. thanks
Old 08-06-2007, 07:47 AM   #4
Slidin240Wayz
Slidin240Wayz's Avatar
Cusco......SPL
Slidin240Wayz is offline   Reply With Quote
Old 08-06-2007, 09:00 AM   #5
nism014
yes you should change both, but you should probably change all the links when your car is super slammed. make sure when you pick up a used ruca that there is no play in the ball joint.
from your post, it looks like you're from hawaii too.
check fh for lonelywanderer's post in the for sale section. He's selling cusco rucas for s14 and I'm sure you can use it on a s13. Its beefy as hell and doesn't have any play at the ball end. I checked. I also know the guy who's selling the silk road rucas (msthtds13 on fh) but I don't know if there is play in that one. you gotta check.
Old 08-06-2007, 02:35 PM   #6
MURPHY
MURPHY's Avatar
MURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfection
Send a message via AIM to MURPHY
while on topic will s14 half moon's work on a s13? or maybe the s13 ones i have a half moon for some reason...?
MURPHY is offline   Reply With Quote
Old 08-06-2007, 02:41 PM   #7
nism014
I think s14 rucas (half moon) can fit on s13 but not the other way around.
