Old 09-14-2007, 10:13 AM   #1
Borund
Borund is not welcome here anymoreBorund is not welcome here anymoreBorund is not welcome here anymoreBorund is not welcome here anymoreBorund is not welcome here anymoreBorund is not welcome here anymoreBorund is not welcome here anymoreBorund is not welcome here anymoreBorund is not welcome here anymoreBorund is not welcome here anymoreBorund is not welcome here anymore
Send a message via AIM to Borund
Wire Harness the same?!
Silly question guys, is the s13 redtop and blacktop's wireing harness the same? I was planning on buying a redtop wireing harness already spliced for s13 to s14, but slapping that on a blacktop.
Thanks.
Borund is offline   Reply With Quote
Old 09-14-2007, 10:46 AM   #2
projekt_s13
projekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfection
Send a message via AIM to projekt_s13
iirc the wiring for the S13 red top is the same as the S13 blacktop, and i think both ecus are interchangeable.
I remember searching a few days ago, since im gonna do the same thing.
You should try searching cuz there are a few good threads that explain more about this.
projekt_s13 is offline   Reply With Quote
Old 09-14-2007, 11:04 AM   #3
Sir
Sir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud of
62/63/E5 are same
the later ones are different.
Originally Posted by drift freaq View Post
I suggest you shut the fuck up.
Sir is offline   Reply With Quote
