Old 09-20-2007, 07:45 AM   #1
SHIFT_*grind*
SHIFT_*grind*'s Avatar
SHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfection
Aftermarket SR O2 housing: which O2 sensor?
To clarify: I have searched the forums for this, found a lot of good info, there's just one thing that confuses me that I wanted to see if anyone could clear up.
Installed an exhaust, test pipe, and knockoff divided turbo elbow yesterday. The elbow I bought used from a guy locally, and it didn't include the fat-to-skinny reducer fitting; it DID include some random fat-type O2 sensor already screwed into it. I install the elbow, find out my SR uses the skinny type, try to use the fat type, drive the car home sputtering and spewing black smoke, etc. etc. So obviously I need to find an adapter to put the skinny sensor in the fat hole of the new turbo elbow.
I found good info here on how to tap an 18mm cap bolt for the skinny sensor. Here's where I'm confused: This thread states that only S13 redtop SRs come stock with the skinny sensor, and all others come stock with the fat type. The sensor I pulled out was a skinny type, but my SR is a 97-98 S13 blacktop. It's a stock swap. So my question is...why would I have a skinny O2 sensor from the factory? Would I stand to gain anything from running a fat type instead? (The car runs fine with the skinny type, I probably get around ~25mpg) Is it possible the car's running a redtop ECU? I only bought the car ~2 weeks ago, so I'm still learning it.
Thanks.
SHIFT_*grind* is offline   Reply With Quote
