Old 10-26-2007, 04:12 AM   #1
all stock
all stock is on the path to ruinall stock is on the path to ruin
s14 ka downpipe similarities?
i have an s14 trust header (4-1) for my s13.
i wanted to know if any aftermarket downpipe for an sr20 would fit, as there are few options for s14 ka downpipes.
also, i heard that the s14 header and downpipe would fit on an s13, just wanted to confirm this.
thanks!
NASA PTD/SCCA ITS
all stock is offline   Reply With Quote
Old 10-26-2007, 06:23 AM   #2
MAGILLA
MAGILLA's Avatar
MAGILLA will become famous soon enoughMAGILLA will become famous soon enoughMAGILLA will become famous soon enoughMAGILLA will become famous soon enoughMAGILLA will become famous soon enough
I haven't checked it my self but the s14 header should fit. a Ka24de is a ka24de no matter what it is in, and the engine mounts are the same. The only thing might be your down pipe length might change.
MAGILLA is offline   Reply With Quote
Old 10-26-2007, 08:31 AM   #3
Sir
Sir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud of
S14 has 4-1 deal from factory going into single downpipe using 3hole gasket
S13 has a 4-2 exh manifold that goes into 2-1 downpipe section.
The reason why its called S14 header is that S13 guys won't be able to use it WITHOUT changing their downpipe as well. BUT replace both and it will fit S13/S14.
Hope that makes sense
Originally Posted by drift freaq View Post
I suggest you shut the fuck up.
Sir is offline   Reply With Quote
Old 10-26-2007, 09:07 AM   #4
projectRDM
projectRDM's Avatar
You can also use an SR downpipe on an S14 exhaust manifold (or the replacement Greddy style header) but the rear flange is rotated a bit, so you'll need a cat or test pipe with floating flanges.
FORMERLY R240NA
Old 10-26-2007, 09:41 AM   #5
all stock
thanks for the help guys.
r240na, that's exactly what i wanted to hear. i'm planning to run a side exit so i just wanted to know if i can buy a used downpipe instead of getting one custom bent.
NASA PTD/SCCA ITS
Old 11-07-2007, 10:25 AM   #6
s13pignose
s13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of light
What about a KA down pipe on the stock s14 manifold..will you neet the floating flange setup. Cause I was thinking of the fr-sport catco cat option that has the flanges and all.
Sorry to thread jack, but its all kinda related
s13pignose is offline   Reply With Quote
Old 11-07-2007, 10:29 AM   #7
projectRDM
projectRDM's Avatar
OE? It bolts right up. There isn't any aftermarket KA downpipe only that I'm aware of.
FORMERLY R240NA
