Old 11-04-2007, 11:42 AM   #1
Sileighty_85
Sileighty_85's Avatar
Cheap Battery Relocation Setup!
I've wanting to do a relocation to the trunk but didnt wanna pay 150+ for a box/kit or whatever it came with. So heres a cost Effective way for those who want to relocate their battery to the trunk.
Items
Snap On Marine Battery Box - Walmart $15
4 Gauge wire - Lowes 12ft for $25 (Maybe 12 1/2 ft to be safe)
Scosche Mini Max Fuse box - Walmart $10
Higher AMP Mini Max Fuse $2
Scosche Battery Terminal - Walmart $10
Neg. Battery Cable Autozone..ect. $10
(Prices May Vary)
Unfortunaly I didnt have a camera at the time
So i'll do this the best I can to explain it.
Step 1
Remove Battery Duh!
For the Pos cable you got that big ass wire for the car then a few white ones, I connected my Main Cable to the right side of the two insert into the fuse box. The white wires + any acessories you use into the left side. Then the Cable from the Battery plugs into the top right of the box.
For the SR I used an 80AMP for the Main Cable and a 30AMP for the accessories.
I belive for the KA you will need a higher AMP fuse for the Main Cable, Due to higher Amperge Draw from the KA Starter
Then feed the the Battery Cable trough the ECU Grommet through the Fire wall
Then run the Cable along the floor
Through the interior Chassis rail just as a precaution wrap the section that runs under the rail with chaff wrap to avoid being rubbed through.
Then feed it up under the rear seats (make sure nothing will pinch the cable to avoid unwanted grounding)
Then underneath the rear interoir pannels (For those of you who still have them)
For the Neg Gound I found the Shock Tower is most effective
Here where the Scosche Terminal comes into play
Then Bam! Your Done
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Sileighty_85 is offline
Old 11-04-2007, 11:44 AM   #2
i need tires
i need tires's Avatar
i need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to all
Send a message via AIM to i need tires
i did the same thing! i dont get why they sell those kits for soo much! looks good man!
JadeCantDrift Blogspot
i need tires is offline
Old 11-04-2007, 12:04 PM   #3
R5SpdAttitude
R5SpdAttitude is an unknown quantity at this point
I am going to have to do that
R5SpdAttitude is offline
Old 11-04-2007, 07:55 PM   #4
aznpoopy
aznpoopy's Avatar
you need a high amp fuse or circuit breaker on the pos as close to the battery as possible. your fuse location does not protect against shorts along the length of the cable through the chassis
additionally, if any of you are not using a sealed battery, add a liner along the edge of the box lid to make it air tight. drill a hole in the box and add a plastic hose, with some sealant around the hose, and run it to some place where the box can vent outside the car.
most racing tech inspection will require a metal battery tie down, so add that in too. use nuts with the integrated liner to make sure the holes you drill through the chassis/battery box for the tie down are airtight as well.
aznpoopy is offline
Old 11-04-2007, 08:08 PM   #5
S14DB
AFC #1
S14DB's Avatar
You should have used 2 or 0 gauge wire.
S14DB is offline
Old 11-04-2007, 08:09 PM   #6
statik
statik's Avatar
statik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond repute
Send a message via AIM to statik Send a message via MSN to statik
good job, but seriously 3A racing vacuum lines? seriously?
97 240sx esaarr | Current Status: SOLD
statik is offline
Old 11-04-2007, 08:13 PM   #7
Sileighty_85
Noway its way too thick My buddy already tried it
後輪駆動車1番
1986 SR86 - 200ish
Old 11-04-2007, 08:15 PM   #8
Sileighty_85
ROTFL Bad Idea on that one, I already changed those out. they really sucked Kept getting Boost Spikes
後輪駆動車1番
1986 SR86 - 200ish
Old 11-04-2007, 08:17 PM   #9
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
2 guage is too thich for what? I relocated my battery to the pass side rear seat and I run a 2 guage cable.
racepar1 is offline
Old 11-04-2007, 08:19 PM   #10
Sileighty_85
I used Solid Core (the thick strands) hard to bend and contour
Thats all they had -o-
後輪駆動車1番
1986 SR86 - 200ish
Old 11-04-2007, 08:22 PM   #11
racepar1
racepar1's Avatar
My car is fuckin gutted like shit so I didn't have that problem. I just ran it down thw trans hump under what's left of the center console.
racepar1 is offline
Old 11-04-2007, 09:27 PM   #12
Sir
Sir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud of
welding cable works better and its super easy to bend.
Than again this thread is called "CHEAP" so I guess you can substitue the crap parts for better quality and end up with better result.
Originally Posted by drift freaq View Post
I suggest you shut the fuck up.
Sir is offline
Old 11-04-2007, 09:35 PM   #13
ecuastyle84
ecuastyle84's Avatar
ecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to all
Send a message via AIM to ecuastyle84
for $10 bucks more you could of got a wesco battery which fits perfectly where the battery tray is and still fit the piping for a front mount...thats how i have it on my car but your setup is cheap and simple...looks good
ecuastyle84 is offline
Old 11-04-2007, 09:48 PM   #14
NemeGuero
No more nissan.
NemeGuero's Avatar
Well your buddy is an idiot. I'm using 2 gage.
4 is a bad idea.
NemeGuero is offline
Old 11-04-2007, 09:54 PM   #15
racepar1
racepar1's Avatar
I just realized that this guy added fuses, WHY? I ran my positive cable directly to the starter, the 2 power wires that attached to the batt cable end and went into the fusebox I ran to the starter as well, and the charge wire for the alternator that goes through the 75 amp maxi fuse I ran all the way back to the battery (although I probably could have just run that to the starter as well). Those additional fuses and holder are not necessary. Also I noticed that he did not run any additional grounds from the engine or intake manifold to the chasis, you should run additional grounds.
racepar1 is offline
Old 11-04-2007, 10:06 PM   #16
S14DB
AFC #1
S14DB's Avatar
How the fuck can wire be too thick? Most relocation kits come with 2 or 0. Starters suck a lot of amps.
S14DB is offline
Old 11-04-2007, 10:08 PM   #17
projekt_s13
projekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfection
Send a message via AIM to projekt_s13
lol wtf are you taking about? You need fuses or your car could BURN to the ground. His weren't placed properly but its better then no fuse at all.
projekt_s13 is offline
Old 11-04-2007, 10:09 PM   #18
racepar1
racepar1's Avatar
Ya, but the stock fusebox HAS fuses. Run your wiring throught the stock fusebox and you don't need to add any extras. The only cable that is not fused is the main power to the starter and that is not fused from the FACTORY.
racepar1 is offline
Old 11-04-2007, 10:11 PM   #19
babowc
babowc's Avatar
babowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfection
$72.. not bad.
this gives full cranking power versus reduced.
especially in colder weather.
My iTrader rating!
babowc is offline
Old 11-04-2007, 10:18 PM   #20
Skullavera
Skullavera's Avatar
Skullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfection
Send a message via AIM to Skullavera
Looks like a decent setup. I used 2 gauge as well for both positive and negative. I grounded the battery in the back and also ran it to the engine bay, to my grounding distributor block.
Reviews/Feedback!
Skullavera is offline
Old 11-04-2007, 10:19 PM   #21
Dousan_PG
Dousan_PG's Avatar
hzahah
this is the worst thread how to ever
WOW
Aaron
Pink GodziRa
Dousan_PG is offline
Old 11-04-2007, 10:23 PM   #22
Skullavera
Skullavera's Avatar
Dude seriously? Of course the main power cable isn't fused because it's designed to go straight to your starter and is very short compared to the long ass 12ft+ of cable you will be running when you relocate your battery. The reason for the fuse is for protection just in case the cable shorts out anywhere along the way from the battery in your trunk to the engine bay.
Reviews/Feedback!
Old 11-04-2007, 10:34 PM   #23
Sileighty_85
4 is a bad idea.
Ive had it in there for a few months no problems
後輪駆動車1番
1986 SR86 - 200ish
Old 11-04-2007, 10:36 PM   #24
racepar1
racepar1's Avatar
My battery isn't in the trunk it is in the passenger rear seat, and my cable isn't 12 ft long it is about 7, and my cable isn't hiding under the carpet and crap cuz I don't have any, And my cable won't short for a VEEEEEEERRRRRRYYYYYYYY long time because I insulated it with heater hose everywhere it rubs and it is held down with insulated clamps.
racepar1 is offline
Old 11-04-2007, 10:38 PM   #25
Skullavera
Skullavera's Avatar
My battery isn't in the trunk it is in the passenger rear seat, and my cable isn't 12 ft long it is about 7, and my cable isn't hiding under the carpet and crap cuz I don't have any, And my cable won't short for a VEEEEEEERRRRRRYYYYYYYY long time because I insulated it with heater hose everywhere it rubs and it is held down with insulated clamps. So yes, I am serious, kiss my ass.
WTF is your problem? I did not flame you or anything just gave info.
Reviews/Feedback!
Old 11-04-2007, 10:40 PM   #26
racepar1
racepar1's Avatar
Fuck you.
The kiss my ass part wasn't actually directed towards you skull.
racepar1 is offline
Old 11-04-2007, 10:42 PM   #27
Sileighty_85
The reason I have the fuses in the front is cuz I dont have a giant ass butt connector to splice the Starter Cable to the New Battery Cable and it was hot as hell out side So i didnt feel like undoing my wiring to run it all the way to the stater. Ive havent had any issues with this setup. Full Amprege cranking power no dimming of lights, or charging problems
後輪駆動車1番
1986 SR86 - 200ish
Old 11-04-2007, 10:44 PM   #28
Skullavera
Skullavera's Avatar
Well it seemed as though it was. Post edited and maybe with the info you posted after the fact I wouldn't have posted what I did. Sooooo..........
I guess in your situation it would be very well protected against shorts.
Reviews/Feedback!
Old 11-04-2007, 10:48 PM   #29
racepar1
racepar1's Avatar
If you are gunna run a fuse though it should be by the battery. If that cable shorts on the battery side of that fuse you are gunna melt down your battery at the least and most likely your car as well.
racepar1 is offline
Old 11-04-2007, 10:50 PM   #30
racepar1
racepar1's Avatar
No problem I shoulda been more specific about that. Oh well.
racepar1 is offline
