Old 02-16-2008, 08:57 PM   #1
niSm095
niSm095 is just really niceniSm095 is just really niceniSm095 is just really niceniSm095 is just really niceniSm095 is just really niceniSm095 is just really niceniSm095 is just really niceniSm095 is just really nice
Need wiring help, what connectors to use?
I wired up my SAFC tonight using these types of connections, only difference I think is that a spade connection plugs into one side:
Problem is, if I bump, tap or wiggle most of the wires the AFC and/or the car shuts off.
Now, I used the ones just like the picture, I believe they were 16-18 gauge. Given the diameter of the ECU wires should I have used smaller connectors like those above, OR....what sort of connections would you recommend?
niSm095 is offline   Reply With Quote
Old 02-17-2008, 01:43 AM   #2
nicku
nicku will become famous soon enoughnicku will become famous soon enoughnicku will become famous soon enoughnicku will become famous soon enoughnicku will become famous soon enough
you dont want to use that man...although i have it on my car from the previous owner....i havent had any problem, though. Once I have time, I am gonna get all the wires soldered...
solering them is the best way man.
nicku is offline   Reply With Quote
Old 02-17-2008, 01:49 AM   #3
importdude
importdude's Avatar
importdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond repute
Send a message via AIM to importdude
if u intend to tap at lease use T-TAPS(allows you to use male spades)
i hate thoese splices makes it unclean, also never liked how is
solder is the way to go
for ecu wires use RED 22-18
importdude is offline   Reply With Quote
Old 02-17-2008, 03:27 AM   #4
Nachtmensch
Nachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond repute
those are absolutely the worst way to do electrical connections. cut, strip, solder, heatshrink, wrap.
you dont plan to remove it do you?
Nachtmensch is offline   Reply With Quote
Old 02-17-2008, 03:37 AM   #5
Sir
Sir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud of
I agree that the connectors you used are worthless.
But proper crimp will work just as good as soldering and is usually easier for people.
Originally Posted by drift freaq View Post
I suggest you shut the fuck up.
Sir is offline   Reply With Quote
Old 02-17-2008, 11:08 AM   #6
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
hehe, you get the idea
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 02-18-2008, 07:36 PM   #7
niSm095
you live you learn right? went back and soldered everything, and it's good to go. Last time I'll ever do anything BUT solder
