Old 04-02-2008, 04:44 AM   #1
phirunt
phirunt is an unknown quantity at this point
s14 cost of turbo installation...
do you guys know the ballpark range for turbo installation? how does that work? do you just go to the auto shop and hand over your turbo parts? how long is the installation process?
phirunt is offline   Reply With Quote
Old 04-02-2008, 06:08 AM   #2
g6civcx
g6civcx's Avatar
How much does it cost to get a meal? It depends. Do you want fast food or 7-course?
Same goes for turbo. Do you want a stock R/R, or full 1000bhp upgrade?
Why don't you post in the local forum and ask people which shop they like? Then contact the shop directly for prices and what's involved.
Old 04-02-2008, 06:38 AM   #3
phirunt
s14
well, i dont want fast food or a 7 course meal, but i do want something in between though. i just want a daily driver, maybe around 300 rwhp (garrett t3/t04 57 trim .63 a/r. godspeed fmic, 3" downpipe, turbo elbow, nismo 740cc, z32 maf, walbro 255, e-mance tune, tial 38mm, hks ssqv bov). i just want moderate boost, maybe around 12-15 psi. thanks.
Old 04-02-2008, 07:27 AM   #4
SHIFT_*grind*
SHIFT_*grind*'s Avatar
SHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfection
You need to be more specific. There are cheaper ways to make 300HP, and there are more expensive ways. For instance, in your clusterfuck list of parts you just threw out there, you listed a T3/T4 and a Tial 38MM wastegate. For either of those you're going to need a new manifold, which equals more money, especially if you go with something other than a $150 Ebay special.
You could stick with stock manifold, or at least one with the same flange/mount design as stock; there are plenty of T2- turbos that mount in the stock location and can easily make 300+ HP.
Do some more research and figure out which route you want to take to get ~300HP, and then try to figure out the install cost. You don't have enough detail right now to figure that out.
My seller review thread
SHIFT_*grind* is offline   Reply With Quote
Old 04-02-2008, 08:13 AM   #5
bigOdom1
bigOdom1's Avatar
bigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfection
stock T28 on 550cc with a z32 maf and FMIC and tune should be what you are looking for
bigOdom1 is offline   Reply With Quote
Old 04-02-2008, 08:38 AM   #6
corriganjoshua
corriganjoshua's Avatar
corriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfection
Send a message via MSN to corriganjoshua
He has a good point slow your roll, first of all get everything figured out your gunna need because there is a lot of little things besides what has already been covered that add up. I cant stress enough how much you need to research before you buy it I mean everything. You can have some of the biggest baddest stuff out on the market right now but without everything matching up your gunna be dissapointed. Try to keep in mind there are usually 3 variable fast,reliable,cheap you can only have 2.
Team Inertia
Cheap,Fast,Reliable you can only have 2.
corriganjoshua is offline   Reply With Quote
Old 04-02-2008, 08:47 AM   #7
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
try to keep everything "bolt in" or close ot that so you can do it yourself instead of paying out the ass to have some shop do it. if you opt for a GT28XX turbo, it's relatively bolt in. like shift grind said, there are cheap and expensive ways to achieve the same results. get everything in yourself, and have a shop profesionally tune it.
clark is offline   Reply With Quote
Old 04-02-2008, 09:24 AM   #8
KA-T_240
KA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond repute
For the list of parts you posted. I would say you are going to be getting charges for at probably 15+ hours of labor, plus the cost of parts and other items(gaskets, fluids)
Find a group of buddys that can help you. Depending on there skills, and your own, you shouldn't have a problem getting the car all torn apart and put together in 2 weekends.
As always, I am going to suggest you get some gauges in there also, even before your turbo upgrade. unless you already have them. Widebands are a must on pre-tuned ecu, just for saftey.
KA-T_240 is offline   Reply With Quote
Old 04-02-2008, 09:47 AM   #9
corriganjoshua
doesnt even say what motor you have im assuming an sr?
Team Inertia
Old 04-02-2008, 09:55 AM   #10
flip3d
flip3d's Avatar
flip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond repute
Send a message via AIM to flip3d
Lets see... what does it cost to install a turbo on an SR20DET...
3/8'' socket wrench set
2 Jack stands
Floor Jack
Ice cold 12-pack
~$200
flip3d is offline   Reply With Quote
Old 04-03-2008, 01:04 AM   #11
ichibans13
ichibans13's Avatar
ichibans13 will become famous soon enoughichibans13 will become famous soon enoughichibans13 will become famous soon enoughichibans13 will become famous soon enoughichibans13 will become famous soon enough
Free.
D- Do
I- It
Y- Yourself
|OO\____/OO| Okinawa JP 2003-2006
Currently: R14 -- Carolina Nissans Elite
ichibans13 is offline   Reply With Quote
Old 04-03-2008, 01:36 AM   #12
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Depends on who you take it to and how much work is needed. Shops charge different rates.
What engine and whats already done to the car???
CLICK HERE!!!
Old 04-04-2008, 03:36 AM   #13
phirunt
i have 96 ka24de. my friends will help me install it, but im just wondering the cost for installation. im pretty sure there are people who had a body shop installed their turbo kit. if the installation fee is cheap or not too bad enough, i might resort to that instead. they have lives too. thanks you guys for answering. i expected more flaming going on :-).
Old 04-04-2008, 10:00 AM   #14
krazydriver
krazydriver is making a name for him/her selfkrazydriver is making a name for him/her self
Originally Posted by ichibans13 View Post
Free.
D- Do
I- It
Y- Yourself
best way to go about it. That way you'll be able to diagnose any potential problem yourself, because you'll know how it went together.
krazydriver is offline   Reply With Quote
Old 04-04-2008, 10:17 AM   #15
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
if u got money and unlimited resources. go for it
Old 04-05-2008, 03:25 PM   #16
Future240
Future Moderator
Future240's Avatar
From one newb to another, your best resourse for info on turboing the ka is going to be www.ka-t.org, or you could juss put in the search button, turboing KA, or go to the turbo KA sticky here. No offense but open ended questions likes this will eventually lead you to being flamed.
Old 04-05-2008, 07:31 PM   #17
fliprayzin240sx
If you can afford it, take it to the pros. If something goes fucking wrong, you can always go back to them and bitch about it. You cant really do that to "friends" who did you a "favor" by installing and blew your engine cuz they forgot to hook up the wastegate.
CLICK HERE!!!
Old 04-05-2008, 10:32 PM   #18
hotlavaflow
hotlavaflow's Avatar
hotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to behold
Send a message via Yahoo to hotlavaflow
Personally I think the hardest part is tapping the oil pan for the oil return. If you can do that or get it done then just install it yourself with your friends. My $0.02
You can run the setup w/o exhaust to an exhaust shop and spent the dollars on new pipes.
hotlavaflow is offline   Reply With Quote
Old 04-06-2008, 12:58 AM   #19
Def
Body shop installing a turbo "kit?" Uhhh... wrong type of shop.
Honestly, if you can't work on a car yourself, you are getting in WAY over your head piecing together a custom turbo setup. Little things will crop up here and there, and you'll probably need to mess with things here and there to get it "perfect."
The 15 hr quote someone else mentioned sounds about right if you bring them EVERYTHING they need and everything fits together perfectly(that's rare). 15 hrs * $65/hr(assuming you find a "cheap" shop) = $975. You develop problems down the road they are NOT going to work on it for free.
If you think a high mileage KA is guaranteed to last forever at 15 psi you are also deluding yourself.
Old 04-06-2008, 01:16 AM   #20
phirunt
s14
thx for all the suggestions you guys. yeah, i guess in the end, i'll have to do it myself with the help from my friends. haha.
Old 04-06-2008, 01:24 AM   #21
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
2 Jack stands
Floor Jack
Ice cold 12-pack
~$200
good deal haha, looking forward to doing this myself too. for sure the 12 pack. thats a must!
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 04-07-2008, 10:58 AM   #22
Taj
Taj's Avatar
Taj is not welcome here anymoreTaj is not welcome here anymoreTaj is not welcome here anymoreTaj is not welcome here anymoreTaj is not welcome here anymoreTaj is not welcome here anymoreTaj is not welcome here anymoreTaj is not welcome here anymoreTaj is not welcome here anymoreTaj is not welcome here anymoreTaj is not welcome here anymore
Send a message via AIM to Taj
Its free!!!!!! DO IT YOURSELF
Taj is offline   Reply With Quote
