Old 05-28-2008, 08:30 PM   #1
JDMSTYLE
JDMSTYLE's Avatar
JDMSTYLE is an unknown quantity at this point
push button start not working...
just the other day my s13 was starting nice and smooth.
but, i decided to be curious george and disconnect one of the plugs from the relay to see if it would start (and it didnt start*what a dumba** i was *). so, i reconnected it and left it and thought that nothing went wrong.
but....
today the car didnt start...anyone know what went wrong by just disconnecting one plug from the relay?
i figured that i either burned out a wire, relay, or fuse somewhere but i dont know where to look.
also when i attempt to start the car all i hear is a click from the relay.
JDMSTYLE is offline   Reply With Quote
Old 05-28-2008, 09:49 PM   #2
surreybc
surreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond repute
you mean the relay by the battery? did you disconnect or reconect with power on? a clicking relay is good. better check your fuses carefully. year and model of car in subject line.
surreybc is offline   Reply With Quote
Old 05-28-2008, 10:15 PM   #3
g6civcx
g6civcx's Avatar
Which relay? Reconnect the best you can and make sure it's tight. Check fuses and fusible links first. Then check back.
Old 05-28-2008, 10:36 PM   #4
its_teddd
its_teddd's Avatar
its_teddd has a spectacular aura aboutits_teddd has a spectacular aura aboutits_teddd has a spectacular aura aboutits_teddd has a spectacular aura aboutits_teddd has a spectacular aura aboutits_teddd has a spectacular aura about
jump start your car :]
its_teddd is offline   Reply With Quote
Old 05-28-2008, 10:44 PM   #5
its_teddd
its_teddd's Avatar
ignore this. double post. sorry.
Old 05-29-2008, 12:15 AM   #6
JDMSTYLE
JDMSTYLE's Avatar
i have jump started the car.
its an 89' with a dohc conversion.
the relay is separate from the engine bay ones..i dont think its the battery one.
somehow i think the problem lies in the fuses, might have burnt one out being an idiot...
Old 05-29-2008, 12:20 AM   #7
kognition
kognition's Avatar
kognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfection
If the relay is clicking, then the solenoid coil is fine. Do a continuity test on the relay poles if you can. Pushbutton start... does it use an aftermarket relay?
kognition is offline   Reply With Quote
Old 05-29-2008, 01:13 AM   #8
JDMSTYLE
JDMSTYLE's Avatar
yes it is a radio shack kind of push button start and im using aftermarket relays..worked great until i messed around with it.
no i dont here the solenoid clicking, i think its just not getting power to the starter at all.
the relay is making the clicking noise.
Old 05-29-2008, 01:45 AM   #9
kognition
kognition's Avatar
Sorry, i meant the solenoid within the relay. Any coil of wire used to activate a linear rod such as in a starter or a relay is a solenoid. You thought i meant the starter. Okay, you should find out what type of relay it is. a SPST (single pole single throw, or DPDT (double pole double throw). You should see those abbreviations on the relay itself. If there is no clicking noise in the relay, then you have no power going to it, or the solenoid in the relay fried.... which is easy to do. But if you do in fact hear clicking in the relay, it still could be damaged to some degree. If it is a DPDT, you could have burnt one of the two solenoids. You should get a multimeter for your tool box. Very valuable tool to have.
Old 05-29-2008, 01:54 AM   #10
JDMSTYLE
JDMSTYLE's Avatar
it clicks. but there is no id on the relay itself.
im guessing its a SPDT it has 4 prongs and is 12V 30A.
looks like this
http://www.seco-larm.com/Images/tblRELAY.jpg
Old 05-29-2008, 02:16 AM   #11
kognition
kognition's Avatar
Yes it looks like it.
Old 05-29-2008, 05:32 AM   #12
g6civcx
g6civcx's Avatar
I'll tell you right now. This problem will be very difficult to diagnose over the Internet because your wiring is not stock and we have no idea what it looks like.
Old 05-29-2008, 07:20 PM   #13
JDMSTYLE
JDMSTYLE's Avatar
the only problem i have now is that i dont think the starter is getting power...
Old 05-30-2008, 12:48 AM   #14
kognition
kognition's Avatar
You should get someone to run a multimeter over everything. Because without that, you are LOST
Old 05-30-2008, 01:03 AM   #15
Smurf_240SX
Smurf_240SX's Avatar
Smurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choices
Send a message via AIM to Smurf_240SX
You prolly blew the ignition fuse in your fuse box from your engine bay.
Smurf_240SX is offline   Reply With Quote
Old 05-30-2008, 04:33 AM   #16
JDMSTYLE
JDMSTYLE's Avatar
what should i run the multimeter on.
i cant figure it out!!! damn seems like a billion wires.
im starting to think that the solenoid is not getting enough amps/power..
Old 05-30-2008, 12:49 PM   #17
-the.k.w.c-
-the.k.w.c- is on the path to ruin-the.k.w.c- is on the path to ruin
for the push button to work in my s14 i needed to add a relay and cut the start wire in 1/2
-the.k.w.c- is offline   Reply With Quote
Old 05-30-2008, 05:11 PM   #18
JDMSTYLE
JDMSTYLE's Avatar
mm..well the push start button was working before.
Old 05-30-2008, 05:49 PM   #19
all stock
all stock is on the path to ruinall stock is on the path to ruin
what's the volts on your battery? disconnect your negative, check for continuity (ohms) from the starter to the push button when you push on the button. if the positive wires aren't making a connection, then isolate the location by eliminating items. test shorter distances to make sure it connects
NASA PTD/SCCA ITS
all stock is offline   Reply With Quote
Old 05-30-2008, 06:14 PM   #20
-the.k.w.c-
or just make sure all your wires have good connections or the button it self is messed
Old 05-30-2008, 07:55 PM   #21
alkemyst
alkemyst's Avatar
alkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nice
Send a message via AIM to alkemyst
QFT...or just pick up a decent electronic one from anywhere cheap and don't look back.
I have recently bought one...never thought I needed it...UNTIL NOW, when I now know many of my previous problems would have been solved much quicker.
YouTube has a lot of multimeter instructions.
Now my Kensai, I curse you to be a Ronin and with the my remaining spirit I, beseech Chimata-No-Kami, to have you wander through time and distance lands, seeking a new master.
alkemyst is offline   Reply With Quote
Old 05-30-2008, 09:45 PM   #22
wiggafly808
wiggafly808's Avatar
wiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to all
Ok guys he called me up and told me that he got it to work..
I think he said one of the wires to the starter came loose or something.
He'll chime in once he gets on
wiggafly808 is offline   Reply With Quote
Old 05-31-2008, 02:34 AM   #23
JDMSTYLE
JDMSTYLE's Avatar
plugged in the ignition wire.
it was unplugged!
what a waste of 2 days of tracing the problem...well thanks guys for helping out!!
Old 06-01-2008, 06:04 AM   #24
alkemyst
alkemyst's Avatar
I am hoping it was unplugged by you rather than just came off. An ignition wire (or pretty much anything coming off a relay) I would hate to have short.
