Old 10-03-2008, 04:09 PM   #1
mkiv98
mkiv98's Avatar
mkiv98 is a glorious beacon of lightmkiv98 is a glorious beacon of lightmkiv98 is a glorious beacon of lightmkiv98 is a glorious beacon of lightmkiv98 is a glorious beacon of lightmkiv98 is a glorious beacon of lightmkiv98 is a glorious beacon of lightmkiv98 is a glorious beacon of lightmkiv98 is a glorious beacon of lightmkiv98 is a glorious beacon of lightmkiv98 is a glorious beacon of light
tightening up steering
So after putting coilovers on, I notice that there is a ton of slack in my steering (there always has been, it's just more noticeable now). In other words, there's very slow response and I can move the wheel around without moving the car.
What is the best way to correct this problem?
Any help would be appreciated.
mkiv98 is offline   Reply With Quote
Old 10-03-2008, 04:12 PM   #2
kuruptR
kuruptR's Avatar
kuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfection
Send a message via MSN to kuruptR
Usually starts with changing tires/wheels. Theres a rubber bushing replacement from Circuit sports that will replace it with a full aluminum piece. Getting harder steering rack bushings, from energy or megan.
kuruptR is offline   Reply With Quote
Old 10-03-2008, 04:24 PM   #3
mkiv98
mkiv98's Avatar
would i need to change the entire steering rack itself?
i want this steering to feel like an s2k
Old 10-03-2008, 05:56 PM   #4
Bushido
Bushido's Avatar
Yanack solid steering rack bushings
Circuit Sports solid column bushing
SPL Pro outer tie rod ends
OEM Z33/32 inner's
If you got the money and depending how bad your rack is, replace it with a rebuilt Hicas unit.
Old 10-03-2008, 06:17 PM   #5
chrisa
chrisa is close to perfectionchrisa is close to perfectionchrisa is close to perfectionchrisa is close to perfectionchrisa is close to perfectionchrisa is close to perfectionchrisa is close to perfectionchrisa is close to perfectionchrisa is close to perfectionchrisa is close to perfectionchrisa is close to perfection
Send a message via AIM to chrisa
i have a hicas rack and rack bushing...the bushings stiffen the steering up and the rack makes it more responsive because it has a quicker ratio over stock. still wont feel like an S2K though but a BIG improvement over stock.
chrisa is offline   Reply With Quote
Old 10-03-2008, 06:23 PM   #6
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
^^^ for the Win!
The Hicas rack can be swapped over with nothing else. Add the steering bushing and solid rear suspension and you'll be a snappy king!
SochBAT is offline   Reply With Quote
Old 10-03-2008, 10:28 PM   #7
cdlong
cdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant future
Send a message via AIM to cdlong
also, what's your alignment? i noticed big changes in steering feel with different toe settings.
it's never going to feel like an S2K, one's a new $35K sposts car and one is a '90 cheap sports coupe.
cdlong is offline   Reply With Quote
Old 10-04-2008, 12:50 AM   #8
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
I'm not sure if our racks have them but you might want to adjust the worm gear preload.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 10-04-2008, 12:53 AM   #9
junn
junn's Avatar
junn is an unknown quantity at this point
i had a similar problem and i got my rack re built.....felt way better!!!....
junn is offline   Reply With Quote
Old 10-04-2008, 01:02 AM   #10
SoguRacing
SoguRacing's Avatar
how much was it to have it rebuilt?
Old 10-05-2008, 03:32 AM   #11
xdumbxguyx
xdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to behold
get an alignment it will probably feel better
because of the contact patch on the floor with a more negative camber
and toe
xdumbxguyx is offline   Reply With Quote
Old 10-05-2008, 04:03 AM   #12
S14DB
AFC #1
S14DB's Avatar
Rack Bushings are like foam rubber. Get some Urethane ones and it makes a world of difference.
Old 10-05-2008, 09:34 AM   #13
derek_s13
derek_s13's Avatar
derek_s13 has a brilliant futurederek_s13 has a brilliant futurederek_s13 has a brilliant futurederek_s13 has a brilliant futurederek_s13 has a brilliant futurederek_s13 has a brilliant futurederek_s13 has a brilliant futurederek_s13 has a brilliant futurederek_s13 has a brilliant futurederek_s13 has a brilliant futurederek_s13 has a brilliant future
Send a message via AIM to derek_s13
second this. what's the dealioio? i don't feel like rebuilding one myself. pain in the dickhole.
derek_s13 is offline   Reply With Quote
Old 10-05-2008, 11:51 AM   #14
The ROMAN
The ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to behold
Also check to make sure the joint on the rack that bolts to your steering column isn't coming loose. Mine started to once and it made the steering feel like what you're saying.
The ROMAN is offline   Reply With Quote
Old 10-05-2008, 12:23 PM   #15
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
The steering wheel is directly connected to the tie rods. The bushings keep the rack steady for more stability. Its the ratio which counts.
check your ball joints.
Bigsyke is offline   Reply With Quote
Old 10-05-2008, 12:33 PM   #16
Dousan_PG
Dousan_PG's Avatar
get an alignment first
thats your real problem.
go from there.
Aaron
Pink GodziRa
Old 10-05-2008, 12:36 PM   #17
silnismo
silnismo's Avatar
silnismo will become famous soon enoughsilnismo will become famous soon enoughsilnismo will become famous soon enoughsilnismo will become famous soon enoughsilnismo will become famous soon enough
OEM Z33/32 inner's
^^your solution
1996 s14-RIP
1990 s13-SOLD
1995 s14-SOLD
1994 E36-Daily
1998 DC2- F.S
Originally Posted by aNskY View Post
your idea of "doing it right" isn't the same as everyone else's... no matter how many kids on here swing from your nuts
silnismo is offline   Reply With Quote
Old 10-05-2008, 12:44 PM   #18
Dousan_PG
Dousan_PG's Avatar
yanacks are ok
mine got all loosey goosey after the past 2 years
thinking get new ones..or probably just rubber ones
one side of my yanack is warped and doesnt hold the rack anymore
its aluminum
should have had it made w/ a stronger material, imo
Aaron
Pink GodziRa
Old 10-05-2008, 01:10 PM   #19
Bigsyke
Bigsyke's Avatar
go from there.
An alignment wont help. If there is play in the steering wheel its either the FLCA ball joints shifting around or the tie rod ends shifting around on the spindle. Everything else is directly connected, unless his tires are sloshing around.
Old 10-05-2008, 01:15 PM   #20
Dousan_PG
Dousan_PG's Avatar
no
toe will make your car feel slooppy and handle like shit
if it happend AFTER he did his coilover change over (as it sounds like it is)
and he HASNT gotten an aligmnet yet
get alignment and go from there.
go re-read his post
Aaron
Pink GodziRa
