![]() Join Date: Mar 2007
![]() Didn't get much help from previous post, I hope to get this clear and straight. I have a s14 sr motor installed into a usdm zenki, and now I want this motor swapped to a usdm kouki.
I wonder if the upper engine harness with ecu attached can be plug-and-play on the kouki. The only wiring modifications I know are mostly on the upper engine harness. While those are alredy been done, are the rest the wirings the same? Am I risking myself to fire the ecu if i do so? hope to get some help this time. Thanks. |
![]() Join Date: Apr 2007
yeah you need to repin.. I can do that for $50, you pay shipping both ways
SR20 & RB20/25/26 in s13/s14 Wiring from $125 to $200.. Best prices EVER. |
#5 | |
He obvioiusly is not capable of doing that unless somone spoonfeeds him what he needs to know. I suppose that is what he is hoping somone may do. If he could do it himself he wouldn't have started this thread now would he?
#6 |
hahah since my first post, people were trying to make a business out of me. Well, I have jdm fsm and a lot of pinout maps. It is necessary I will do it myself. But the point of this thread is trying to ask for help and confirmation if this works.
#7 |
Use the fsms, it will work, good luck! I get paid $100/hr - if i'm gunna spend an hour doing any research that doesn't benefit me in any way, i want some kind of compensation... time is money.
#8 |
![]() Join Date: Apr 2003
You need to quit shitting in everyone's thread about your wiring services. If you're that hard up for cash that you can't help out someone without payment (isn't that what online forums are for?), then fucking PM him about it.
This is like the 3rd thread I've seen lately that you're soliciting work from.
#9 | |
![]() I am simply offering them a cheap alternative because nobody else is going to offer them a solution. This kid had to post a second time to get anywhere. If somebody's best answer is "go to wiring specialties" or no post at all then I don't see how me "soliciting my services" does any harm. If you want to spoonfeed him then go the fuck ahead whiney man. Yeah maybe if he wanted to know how to wire up a few sensors I wouldn't mind helping. But everything he needs is already on the internet, it will be a learning experience. If hes too lazy than he can pay. So STFU Because the wiring is simple and easy then I will give it to him The only thing he has to do is change two wires on the f3 plug of the harness thats it. One wire is for AC switch the other is just a ground. On the F3 Plug on your already converted engine harness (the large white plug that goes under the dash on your s14) Move Cut wire going to Pin 16 (Color: Yellow/Black) on your f3 plug and splice it to the wire going to pin 46 (Color: Orange/blue) (if there isn't one then take extract wire and pin from either port 35, 36, 39 (all empties) and splice that to the wire on pin 16 then mount the pin in hole 46. Next steal a pin/wire from either pins 9, 13, or 14, or use the large pin that you got from the Yellow/black (pin 16) wire and plant that into the empty socket on pin #2. Run that wire to ground on the chassis. Here is a pdf showing your F3 plug and where all pins go on the 97 S14: http://www.rbforums.org/pdfs/1997f3pinout.pdf
SR20 & RB20/25/26 in s13/s14 Wiring from $125 to $200.. Best prices EVER. Last edited by opponheimer; 03-25-2009 at 12:54 PM.. |
#11 |
He's not asking to be spoonfed. Maybe pointed in the right direction? His question isn't a basic one, nor is it one that I've seen asked a bunch of times. If YOU know where he can look to find the answers, maybe you can help him out?
That being said; OP, sorry I don't know what needs to be repinned, so I'll quit posting ![]()
#12 | |
Look up ![]()
#15 |
Yeah that wire on pin 16 is the ac switch... You may not even need to wire it in, but do that anyways. I was surprised myself how similar they were.. Thats all you ahve to do is rewire the F3 plug..
#17 | |
Hes running the exact same ecu so the eccs plug doesn't need to change a bit... The only thing that is changing is the chassis harness that he is plugging into. Honestly, he could probably plug the sucker in and it will work fine for him. He just needs to ground pin 2 on the F3 plug and run wire 16 to 46
