how do I make a jdm s13 gauge cluster work
Hi I have 1990 s13 that has a sr20det in it ,it has a single cam gauge cluster in it right that does not reed the rev or speed so I'm going to pick up a jdm s13 gauge cluster will it just go in or is there more parts/ work that need's to be done to make it work thx guys for the help
ok I just put in the jdm Analog cluster and it did not work, works the same as the k24e gas and temp are good but no rev or speed there's power going to it and all that but it's just not working , could it be cuz the car was a auto be4 plz help thx what sould I look 4
#7 |
![]() Join Date: Dec 2006
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
well u stated u have a sr20det, u need to change ur speed sensor so u can read the speed and tach. i would recommend that u just get a cluster from a junkyard. If it is from a dual cam u shall have to change out the speed sensor to a dual cam speed sensor. either way u need to change the speed sensor if u want to keep ur jdm cluster or just get dual cam cluster and still change ur speed sensor. Basically Get a speed sensor either froma junkyard or shop online and get one. Also dont geta jdm speed sensor just because u have a jdm engine a usdm dual cam cluster probablly would have been cheaper and easyer to get then the jdm FYI
#8 | |
#9 |
![]() Join Date: May 2004
speed sensor will not affect the tach working. I think the wiring was not done right when the SR swap was done. Under the dash by the ECU there is a white plug that leads from the ecu, and plugs into the dash harness. Has that been converted? Is it pluged in? Are the Yellow/red stripe(tach signal) Yellow/green stripe (speed signal) connected?
PS. The JDM and USDM speed sensors are the same no need to swap them |
#10 |
I do have the Yellow/red stripe(tach signal) hook up and I may sure there was a power from the ecu to the dash harness and to the Analog cluster and still no rev
#11 |
![]() Join Date: Dec 2007
Trader Rating: (68)
![]() Feedback Score: 68 reviews
here's alittle example just incase you need it.
http://zilvia.net/f/s-chassis/248941...r-cluster.html
Late Night Crew... #02 <3 Bought anything from me? Please leave me a review! ![]() http://zilvia.net/f/private-sellers/...meistah21.html |
#12 | |
#13 |
![]() Join Date: Sep 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
go to frsport.com (they have a tech section on the left hand side of the page, scroll down a bit) and verify that your wiring is correct and that all your plugs are connected properly. If that doesn't work, get the FSM and a test light or mulimeter and start checking for voltages.
#14 |
![]() Join Date: May 2009
![]() Feedback Score: 12 reviews
i have the same problem...but everything works fine on my boost controller...but i will defenatly try all of this wen i get a chance...i tried to convert the harness but i guess i did it wrong so i will try all this again...=]
