Old 02-03-2010, 12:51 AM   #1
jimmytango00
jimmytango00's Avatar
jimmytango00 is close to perfectionjimmytango00 is close to perfectionjimmytango00 is close to perfectionjimmytango00 is close to perfectionjimmytango00 is close to perfectionjimmytango00 is close to perfectionjimmytango00 is close to perfectionjimmytango00 is close to perfectionjimmytango00 is close to perfectionjimmytango00 is close to perfectionjimmytango00 is close to perfection
Send a message via AIM to jimmytango00
WTF is wrong with this car.
3 days ago i woke up and my car would not start.
OK... first thing i did was
1. Checked the battery (it was low so i got it recharged)
I threw the battery back on and still nothing. Fans turn on and lights turn on but i only get the relay click when i try and turn the car on.
2. I ran a direct wire to where the starter signal wire plugs in and ran it straight to the battery, still nothing, the starter did click, but the car did not start. So i pulled the starter and got it tested (passed) . I threw the starter back on and tried the hammer tap but car still wont start.
3. I tried push starting the car and it wouldnt start, so i pull the alternator and i get it tested . Alternator fails everything, so i buy a new one and throw it on. Still wont start, only getting the relay click.
So pretty much what im asking is what else can i check?
Tomorrow im checking the ECU, Continuity, ignitor, coil packs and grounds. Am i missing anything?
Could it be the relay on the wire that hooks up to the battery? i believe it runs to the fuse box.
Any help would be much appreciated.
jimmytango00 is offline   Reply With Quote
Old 02-03-2010, 12:59 AM   #2
hassanbakar123
hassanbakar123 is an unknown quantity at this point
direct wire from where to where? battery to starter?
hassanbakar123 is offline   Reply With Quote
Old 02-03-2010, 01:14 AM   #3
jimmytango00
yes.
i hooked the wire up the little metal piece where the signal wire goes to then with the other end just touched the battery. Not sure if i did this right but from what i looked up that was how they explained it.
Old 02-03-2010, 02:09 AM   #4
lilrusty
lilrusty's Avatar
Trader Rating: (37)
lilrusty is an unknown quantity at this point
Feedback Score: 37 reviews
does the motor at least crank??
lilrusty is offline   Reply With Quote
Old 02-03-2010, 02:18 AM   #5
mrmephistopheles
mrmephistopheles's Avatar
How sure are you that the battery is good? Have you tried using a known good battery?
Originally Posted by PHLIP
Old 02-03-2010, 02:20 AM   #6
xpertsnowcarver
xpertsnowcarver's Avatar
Trader Rating: (44)
xpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud of
Feedback Score: 44 reviews
^^I wasn't hesitant to post that.
Sometimes the starter circuit making a click could mean your battery cannot put out enough amperes to crank granted the voltage may be high enough. It's happened to me and on several different cars.
My YouTube Channel
xpertsnowcarver is offline   Reply With Quote
Old 02-03-2010, 02:40 AM   #7
az_240
az_240's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
I had the same problem a while back and it was my alternator.
What alternator did you get? I've seen brand new aftermarket alternators fail.
Also try using a known good battery.
Old 02-03-2010, 03:34 AM   #8
smoothcoupe
smoothcoupe is an unknown quantity at this point
if you tested your battery and starter and they both pass, and your car will not crank, then its either the clutch start relay, bad battery, or bad ground. THERE CAN NOT BE ANYTHING ELSE WRONG WITH YOUR CAR. try wiggling the ground to the intake manifold, and make sure you have good battery terminals that make good contact
smoothcoupe is offline   Reply With Quote
Old 02-03-2010, 04:58 AM   #9
jrocslider
jrocslider's Avatar
jrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfection
The bad alternator drained the battery. Check it again. I've also had the same problem before. I had to replace my battery and have had the same optima since.
jrocslider is offline   Reply With Quote
Old 02-03-2010, 05:41 AM   #10
fos240
fos240 is an unknown quantity at this point
Send a message via AIM to fos240 Send a message via Yahoo to fos240
the solenoid could be bad. it will still click, but not actually engage the starter or allow it to spin. when they check it at a parts store, they don't check the solenoid, only the starter motor itself. i did a write up on this on another forum.
SR20 starter problems? - Carolinanissans.com
frankie
fos240 is offline   Reply With Quote
Old 02-03-2010, 05:58 AM   #11
sidedrifts13
sidedrifts13's Avatar
Trader Rating: (29)
Feedback Score: 29 reviews
I think its gonna be the battery, sometimes depending on the battery you have you have to use a agm battery charger, somebody correct me if I am wrong.
sidedrifts13 is offline   Reply With Quote
Old 02-03-2010, 06:29 AM   #12
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
Have you tried jumping the solenoid signal wire straight to power? A common cause of no-start issues on 240's is the ignition switch. If it starts when you jump the little signal wire straight to power then the switch is likely bad. They lose contact and can't relay enough amperage to actually kick the starter in. I had it happen to my car and a couple other 240's as well, both s-13 and s-14.
Old 02-03-2010, 07:09 AM   #13
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
see if the car starts if you have someone push you until rolling and pop the clutch.
clark is offline   Reply With Quote
Old 02-03-2010, 07:28 AM   #14
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
+1 on battery. You can charge it all you want and get it up to 12V but if its dead cranking power wise, it wont start the car.
CLICK HERE!!!
Old 02-03-2010, 08:04 AM   #15
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
Everything that's been said and check to make sure the fuel pump is coming on.
Old 02-03-2010, 09:10 AM   #16
ericcastro
ericcastro's Avatar
msglength.........
Old 02-03-2010, 09:13 AM   #17
jimmytango00
the battery is an Oddessy pc625 Drycell battery and it tested at 13.8v and 368 CCA's so i know it has more than enough to start.
frankie
I'm borrowing a starter today so i'll see if this was the case.
I tried jumping the solenoid but all i get is a click from the starter, when i hook everything normally again, the starter doesn't click.
Fuel pump comes on.
The only thing that worries me is that i cant even push start the car even with a new alternator.
If the ignition switch was bad or if the starter was bad i should still be able to push start correct?
Im checking voltage and continuity and the ECU today. If i have extra time im swapping starters.
Old 02-03-2010, 09:21 AM   #18
clark
clark's Avatar
if you can't push start, then it's not your starter.
i'd now start checking to make sure everything has good clean contact such as your main ground cables and alternator cables and battery terminals...
i'm talking shiny metal clean with a file/wire wheel/sand paper.
check your big 75a fusible links.
Old 02-03-2010, 09:56 AM   #19
steve shadows
steve shadows's Avatar
It just sounds like your battery died and now you dont have enough to fire over the starter.
Or the starter is dead.
Like Me on FaceBook !
Old 02-03-2010, 10:24 AM   #20
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
im aiming towards the starter as well...you changed alternator, charged battery...im assuming you checked ur 75A fuse and its good...?
PSN
& XBL GT : Wh0pp3r68
CLUB LEXUS : Wh0pp3r
Old 02-03-2010, 10:29 AM   #21
jimmytango00
yeah all that stuff was checked.
end result:
i went back out and before i tore this bitch into pieces, i went through all my wiring again and double checked and made sure everything was getting power, checked my grounds , etc.
So i decided to unplug the starter relay and clean it up a bit, threw it back on and boom, car fired up. s
thanks for all the replies guys, zilvia comes through again :ghey:
Old 02-03-2010, 10:34 AM   #22
DRIFTING_SIL_EIGHTY
DRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to behold
Though you did have the battery checked, I say check it yourself. Same thing happened to me with a short in the harness due to an accident (caused a drain). Took it to Kragen and everything checked out. But when trying to start the car, it would drop to 8-9 volts (static it was 12.4). Have another person check it with a multimeter while your trying to start it.
DRIFTING_SIL_EIGHTY is offline   Reply With Quote
Old 02-03-2010, 10:41 AM   #23
jimmytango00
read the post above you,
Car started already.
thanks for the info though = )
Old 02-03-2010, 10:47 AM   #24
Sterlz
Sterlz's Avatar
Sterlz is an unknown quantity at this point
This happened to me. Is the car manual? If so, check the neutral position switch (that click you hear when you fully press the clutch pedal), if it's broken/missing, just put a bolt/screw so that there can be contact. I discovered that on accident
Sterlz is offline   Reply With Quote
Old 02-03-2010, 11:00 AM   #25
DRIFTING_SIL_EIGHTY
Haha I had clicked on the thread and the last post was Dalaz. Good to hear you got it started.
Old 02-03-2010, 11:12 AM   #26
ericcastro
ericcastro's Avatar
Read the thread first before replying.
Car was started a few post back
Old 02-03-2010, 11:18 AM   #27
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
i swear...these cars...its always the small shit that gets you...good shit though...
PSN
Old 02-03-2010, 11:59 AM   #28
jimmytango00
seriously! $113.91 and 3 days later... and its just a fucking relay!
new alternator looks nice though and lifetime warranty FTW!
Old 02-03-2010, 03:03 PM   #29
fos240
these little pita problems are more common in s13's more so than s14. yet another reason s14>s13.
frankie
Old 02-03-2010, 03:28 PM   #30
jimmytango00
FUCK! so i went back out just to quadruple check and make sure the car turns on and BOOM! shits doing the same thing again.
Since the car started i know the starter is fine, grounds are good, battery is good and relays are good. I dont need to have the clutch pushed to turn my car on so i know that little clip behind the clutch is not broken.
only thing left is that my ignition switch is failing.
Any other ideas guys?
