Old 05-15-2010, 03:49 PM   #1
KevinZtwin
KevinZtwin is an unknown quantity at this point
CA Z32TT front brake calipers, many other upgrade and OEM parts. Stillen, FMIC, Methanol
I have some parts that I would like to clear out of my garage and in the process get more funds to buy other upgrades. All prices are before shipping, add 3% if using paypal. Local Socal people can arrange a pickup if needed and some I might be able to deliver for.
Snow Performance Methanol Injection Kit (stage 2): $450 for everything with all the extras/upgrades
- Upgraded 220psi Pump (150psi is the regular one)
- Upgraded solenoid (new, never installed, Cost $50) PN# 40060
- 375mL nozzles (x2)
- Variable injection controller (gradually increases injection from 8psi all the way up to 25psi)
- Safety Injection Module (in case you run out of fluid or for some reason have an interruption in methanol injection it will lower your boost or retard your timing to save your motor) - Cost $159
- Hardpipes with bungs welded on (you need couplers and clamps)
- No tank, the windshield washer fluid tank was used utilizing the low level indicator light
- All manuals, everything needed to install
Stock Tail Lights (all three pieces) in excellent condition. I have some leftover sealant, but you will probably need more. Sorry for the dust: $100
I have 2 of these leftover rolls of the weather sealant
OEM 1990TT Rear Traction Rods: $15 each
STILLEN Front Crossdrilled rotors (11"x30mm): SOLD
STILLEN Front Tension Rods (adjusts Caster). I had an alignment shop say they could not get one of them loose to adjust it, so I got a new set. If you can get it loose they will work fine, or just leave them in the current position which should be okay: SOLD
1990TT OEM front 30mm calipers with Stillen metal matrix pads with some life left in the pads: SOLD
AMS 3” Expansion Down pipes (5 bolt) with O2 bungs (new, never installed): $300
AMS TT Exhaust Manifolds (new, never installed): $450
OEM TT Precats/downpipes: $60
OEM Rear suspension dampening adjusters: $10/pair
OEM shift knob: SOLD
SS Braided brake lines: SOLD
Sway bar end links (front OEM, rear Stillen): $30
CX Racing FMIC 3” Core with couplers, piping, and T-Clamps (prefer local pickup or I can deliver for some people), new, never installed: $300
OEM TT SMICs - $60/pair
OEM TT HICAS Actuator - $50
OEM TT HICAS Rack - $60
Tokico HP shocks with Eibach Prokit Springs (approx. 25k miles) - $250
One of the mounting studs on the rear is a little larger, you will either need a 14mm nut or swap in a 12mm stud/nut like the rest of them. I am assuming the installer snapped a stud and used what he had laying around. Dust boots are shot from being in a really hot/dry climate. No problems with them, just upgraded to coilovers.
Prefer PM or email
[email protected]
Located in Palm Desert, CA. But I make trips to the Long Beach area almost every week if you need delivery.
Kevin
KevinZtwin is offline
Old 05-15-2010, 04:38 PM   #2
mojos13
mojos13 will become famous soon enoughmojos13 will become famous soon enoughmojos13 will become famous soon enough
Z32 front calippers & stillen tension rods, PM sent!
mojos13 is offline
Old 05-15-2010, 10:48 PM   #3
KevinZtwin
Z32 Calipers SOLD
Stillen Rotors: SOLD
Old 05-16-2010, 12:14 PM   #4
Alan_G
Alan_G is an unknown quantity at this point
will the rotors only fit on z32 calipers?
Alan_G is offline
Old 05-16-2010, 09:31 PM   #5
KevinZtwin
Z32TT: Front Calipers: SOLD
Stillen Tension Rods: SOLD
Stillen Brake Rotors: SOLD
Shift Knob: SOLD
Everything else: Available
Old 05-17-2010, 10:21 PM   #6
KevinZtwin
Brake lines sold
Old 05-18-2010, 07:51 AM   #7
racerx2k1
460
racerx2k1's Avatar
Originally Posted by KevinZtwin View Post
Z32 Calipers SOLD
Shift Knob: SOLD
Brake lines sold
racerx2k1 is offline
brakes, eibach, fmic, meth, z32
