Old 11-16-2011, 07:19 PM   #1
trexm3
trexm3 is an unknown quantity at this point
FRESH SC400 8K this WEEK ONLY!!!
*****need this gone this week or im just keeping it in storage .. have my dd lined up and need more $$ for the downpayment so no trades anymore unless its a sick ls1 FC or built right s14 ******
Specs
1992 SC400 with 112k original miles Black on Tan. 1UZ-FE (V8)
Supra R154 trans had 78k miles when pulled from the car "I just replaced the last one due to a few bad synchros.
Specs
the sc400 was never offered in a manual and there are barley any swaps out there ive only ever seen 4 total between youtube and the forums..
1uz and trans are strong and can be vouched for
POWAAA
S-AFC (tuned)
Custom equal volume long extractor headers (Rush AU)
Carsound cats, x-pipe, flowmaster mufflers
Walbro 255LPH high pressure fuel pump
1.5 way LSD from 94Supra N/A with 4.27 gearing
Custom one-piece driveshaft
SUSPENSION ISSHHH
8-point full roll cage
Daizen Front Control arm bushings
Daizen Rear Control arm bushings
Daizen Front and Rear Sway bars
Daizen front and rear sway bar bushings
TEIN HA coilover system
Daizen rear camber control kit
LOOKERS
Just got it out of the body shop, the car has zero dings or scratches.
door cards
Origin front bumper
Origin rear bumper
Vertex rear spoiler(i removed it but still have it)
HID low and highbeams
V-speed side skirts
Painted Carbon Fiber Hood with hood pins
GUTSSS
Cage "unpainted but prepped n ready for paint"
98 Supra TT front leather seats
Clarion 2din CD/MD player
"have single din setup,waiting for some time to put it in"
Custom Laser blue dash needles(by lextech lighting).
Nakamichi factory system
replaced climate control lights with 97+ scheme
optional cupholder added
ROLLIN N STOPINN
I-forged 19x8.5F 19x10R "need to be refinished or powdercoated"
Tires = 245/35/19F 275/30/19R
Supra TT front brake upgrade with cross drilled rotors (Brand new)
Lexus SC brakes rear (Brand New)
Goodridge SS brake lines (all four corners)
EXTRA
A/C system converted to R134 from R12
New Supra spare
mmm NEW STUFFF
CRD custom bellhousing
CRD custom flywheel
CRD custom ring gear
Exedy Clutch
Exedy pressure plate
Spigot Bush (this is from a turbo MKIII)
Throw Out bearing (this is from a turbo MKIII)
slave cylinder & push rod (this is from a turbo MKIII)
Slave cylinder and bolts (this is from a turbo MKIII)
release bearing (this is from a turbo MKIII)
pivot ball (this is from a turbo MKIII)
(6) M12 x 1.25P x 50 long original
Toyota
bolts -bellhousing to motor (OEM)
CRD supplied (3) M10 x 1.25P x 45 long original Toyotal Bolts - Bellhousing to motor (OEM)
CRD MKIII turbo slave cylinder (this is from a turbo MKIII)
*R154 transmission from soarer
TT
(this can be from a turbo MKIII)
*MKIV soarer TT tailshaft (this is from a late model MKIV
pilot bearing (from a turbo MKIII)
Flywheel flex plate bolts (8) M10 x 1.25 pitch x 26 long High Tensile Bolts. (OEM)
SC300 clutch pedal 58804-24030-03
SC300 clutch pedal box sub assembly 47101-24060
SC300 brake pedal
SC300 brake pedal box sub assembly 31301-24050
SC300 clutch pedal pad 31321-14020
SC300 brake pedal pad 31321-14020
SC300 shifter boot
SC300 shift knob
SC300 shifter trim bezel (specify with or without heated seat)
supra 6speed master cylinder 31410-14310
SC300 hardline for master cyl
MKIII turbo hardline for slave cyl
bads- needs a extremely good interior detail
** car currently is on a winter 350z setup and might be having the iforged refinished**
**yes i have the other seat i keep it out when im transporting tires**
maybe ill get some pro pics taken soon so you can see more then the crappy phone pics
8K THIS WEEK ONLY!!!! 856 725 7566 or pm
how it sits currently
trexm3 is offline   Reply With Quote
Old 11-16-2011, 08:23 PM   #2
TougeLabs
TougeLabs's Avatar
TougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to behold
Send a message via AIM to TougeLabs
Unsure why someone doesn't scoop this up ! I love and miss this car greatly !
TougeLabs is offline   Reply With Quote
Old 11-17-2011, 09:06 AM   #3
flip3d
flip3d's Avatar
flip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond repute
Send a message via AIM to flip3d
Damn. What rpm at 80? Like 3600?
flip3d is offline   Reply With Quote
Old 11-17-2011, 11:50 AM   #4
trexm3
ill check today if take it out for , and lets get this thing sold as stated i either need to sell it this week or my dd will no longer be able to be held for me at the dealer
Old 11-20-2011, 09:44 AM   #5
trexm3
bumppp it before i decided to keep it or trade it since no one has cash anymore
Old 11-20-2011, 03:11 PM   #6
bikrman2
bikrman2's Avatar
bikrman2 is an unknown quantity at this point
Send a message via AIM to bikrman2
Dammit I want this car! Trade for my vert? I'll fix it and throw in a vq35 long block and trans? I have a F/S thread on here
Originally Posted by wangan_cruiser View Post
if you dont have any valuable information GTFO.
bikrman2 is offline   Reply With Quote
Old 11-20-2011, 03:18 PM   #7
delado
delado's Avatar
delado is an unknown quantity at this point
This thing is stupid wicked. I'd trade you if you weren't so far. GL mate.
delado is offline   Reply With Quote
Old 11-20-2011, 06:27 PM   #8
trexm3
thanks i know if you were in fl we would of worked something a while ago hahah... meet in the carolinas??!!
get the vq in and kit that thing out, im not looking for a project right now really though...
thanks for the interest though man
Old 11-20-2011, 06:50 PM   #9
alwayss13
alwayss13 is an unknown quantity at this point
Any interest in a 2006 sentra ser with a VQ35 swap?
alwayss13 is offline   Reply With Quote
Old 11-20-2011, 07:24 PM   #10
trexm3
no thank you glws
