Old 01-17-2013, 11:22 PM   #1
fsuarez
fsuarez's Avatar
fsuarez is an unknown quantity at this point
Send a message via AIM to fsuarez
RB downpipe / downpipe rubbing
so i just replaced my old turbo with a gt28 from cxracing.
everything has been set for it finally got it on and works fine, problem is since the turbo is slightly shifted it forces the down pipe and steering column to rub against each other.
please any suggestions would be helpful
i found that if i raise the downpipe/piping it might clear, or maybe an extended elbow for the downpipe, idk
motor: rb20det
chassis: 1990 240sx base model
fsuarez is offline   Reply With Quote
Old 01-17-2013, 11:29 PM   #2
shiftdrift
shiftdrift's Avatar
Trader Rating: (42)
shiftdrift is an unknown quantity at this point
Feedback Score: 42 reviews
Take hammer. Massage down pipe. Profit.
SW Fab
shiftdrift is offline   Reply With Quote
Old 01-17-2013, 11:36 PM   #3
fsuarez
fsuarez's Avatar
its a ceramic downpipe...i dont think that'll work
Old 01-19-2013, 10:09 PM   #4
STR8E180
STR8E180 is an unknown quantity at this point
ceramic ? u mean cast?
STR8E180 is offline   Reply With Quote
Old 01-20-2013, 12:19 AM   #5
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
the photo you posted is of a cast downpipe.
perhaps you should contact the manufacturer and make them aware of this problem.
in the mean while, i would suggest buying an aftermarket elbow, and bashing it with a hammer to create the required clearance.
what exhaust manifold are you using?
Old 01-20-2013, 01:32 AM   #6
fsuarez
fsuarez's Avatar
yeah cast, my bad
i found that an aftermarket elbow with a flange will give me enough clearance, well i hope it does, wont know til the parts arrive, but ill keep this thread posted on what happens
im using the stock manifold
Old 01-20-2013, 10:55 AM   #7
brndck
brndck's Avatar
Was the cxracing turbo sold/advertised as a direct for replacement for your stock turbo? Or was it just a universal t28?
I've heard of people having this issue with tomei manifolds, but never with oem manifold.
Old 01-20-2013, 12:38 PM   #8
fsuarez
fsuarez's Avatar
its advertised as "bolt on fitment, fits stock manifold and downpipe" and its also advertised for "89-99 Nissan 240SX S13, S14, Silvia Chassis with RB20DET RB25DET Engine Swap"
with the last part i would expect the turbo to not give me problems with a 240sx but it did, oh well
even so the guys over at cxracing are legit, they'll hook it up when it comes to prices if you go in person but dont carry much for rb20 swaps, carry more for sr swaps
Old 01-20-2013, 12:42 PM   #9
fsuarez
fsuarez's Avatar
i also found that if i were to raise my motor slightly it would clear the problem, but not sure if it would create unnecessary vibrations and other problems
Old 01-20-2013, 12:59 PM   #10
STR8E180
I think on a right hand drive car it would fit
Old 01-20-2013, 01:12 PM   #11
fsuarez
fsuarez's Avatar
If I could, I would
Old 01-20-2013, 03:04 PM   #12
brndck
brndck's Avatar
lol of course it would! the steering shaft would be on the other side!
op: here is the solution. convert to rhd. i've got a rhd firewall and steering column for sale.
Old 01-21-2013, 01:18 AM   #13
fsuarez
fsuarez's Avatar
thanks for the offer, but for now im just trying to get my car running
Old 01-21-2013, 10:48 AM   #14
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Raise it then. Better yet, grind where it rubs or notch it but cutting it, then welding it back up.
CLICK HERE!!!
Old 01-27-2013, 10:31 PM   #15
fsuarez
fsuarez's Avatar
the flange worked perfect, gave it more than enough room
Old 01-27-2013, 10:41 PM   #16
OrangeVirus1
OrangeVirus1 is an unknown quantity at this point
gt28 from cxracing.
OrangeVirus1 is offline   Reply With Quote
Old 01-28-2013, 10:42 AM   #17
KoukiPuffs200
KoukiPuffs200's Avatar
KoukiPuffs200 is an unknown quantity at this point
I had the same issue when I installed my specR t28, you have to buy the Megan elbow or Tomei. I'm not sure of any others that fit, but the single port elbows is what you need. the dual port ebay $50 one will NOT fit. I went with Megan and fix the problem.
Also might try reclocking the turbo just a hair.
::Hit & Run::
KoukiPuffs200 is offline   Reply With Quote
Old 01-28-2013, 11:26 AM   #18
Srsil
Srsil is an unknown quantity at this point
Get a hold of mckinnley and just buy the spacer u put betweeb ur o2 housing and the turbo moves the o2 housing back and will clear the steering shaft guys using a factory r32 crossmember have been doing it forever
Srsil is offline   Reply With Quote
Old 01-28-2013, 11:37 AM   #19
OrangeVirus1
Reclocking the turbo won't accomplish much, since you can't move the hotside when reclocking a turbo, it only attaches to the manifold one way.
Old 01-28-2013, 01:03 PM   #20
fsuarez
fsuarez's Avatar
yeah i did this, it worked
Old 01-28-2013, 01:33 PM   #21
Ilya
Ilya's Avatar
Ilya is an unknown quantity at this point
Can we get an image of this spacer?
Ilya is offline   Reply With Quote
Old 01-28-2013, 02:08 PM   #22
fsuarez
fsuarez's Avatar
didnt really take a picture of it, but bought it from ebay:
Nissan Skyline RB20 RB25DET Turbo Downpipe Weld Flange | eBay
ill take a picture of it already on later tonight
Old 01-28-2013, 03:23 PM   #23
Ilya
Ilya's Avatar
so this spaces the oem turbo elbow enough to clear the steering shaft? how much room are we talking about?
Old 01-28-2013, 05:27 PM   #24
fsuarez
fsuarez's Avatar
well luckily mine was not rubbing against it hard, only glancing it but when turning the wheel it scrapped it bad,
it moved the elbow about 3cm, doesnt hit anymore, and even at its worse the elbow and the steering column only come close to about a cm
i was still able to connect my piping without making cuts, only had to pull my piping back a bit for the holes to ling up
ill post photos later tonight
are you having the same problem?
Old 01-28-2013, 08:33 PM   #25
Ilya
Ilya's Avatar
Well my goal is to have an RB in my convertible here pretty soon, and while I wait I am doing as much research as I can, and one thing that concerned me was the steering shaft clearance, however, you figured out an inexpensive yet effective way of solving it, THANK YOU! Which mounts are you using? and I am guessing you need two exhaust turbo gaskets?
Old 01-28-2013, 08:45 PM   #26
dbiz
dbiz is an unknown quantity at this point
i had same problem just used a hammer and made it happen
dbiz is offline   Reply With Quote
Old 01-28-2013, 11:45 PM   #27
fsuarez
fsuarez's Avatar
so you didnt have a cast elbow...
Old 01-28-2013, 11:48 PM   #28
fsuarez
fsuarez's Avatar
im not sure on the mounts, the swap was already in there when i bought it
Old 01-28-2013, 11:52 PM   #29
fsuarez
fsuarez's Avatar
heres the picture of the flange
Old 01-29-2013, 06:21 AM   #30
Ilya
Ilya's Avatar
HOLY CRAP THATS BEAUTIFUL!!!! Thank you for all your help!
