![]() Join Date: Mar 2014
S14 lsx part out (SIKKY, APEXI, Hp TUNNER, Wiring Specialties)
Sikky headers with custom y pipe that connects to a real apexi dual n1,
The headers are v band and from the y pipes thats are custom tig welded to the exhaust the entire piece is one part no flanges and resonator removed. asking $1000 for everything headers alone are woth that. Sikky motor mount kit: Basic Mount Kit Includes: Aluminum Race Oil Pan 7 Quart High Capacity Design 6061 CNC Machined Flanges from 1/2″ Aluminum Retaining OEM like Structural Rigidity (not flimsy like other aftermarket pans) Rear Flange at Bell Housing Allows Install of Factory Dust Shields Baffle and Trap Doors to Prevent Oil Starvation New OEM Oil Pan Gasket Custom Oil Pickup Assembly Remote mount filter Kit -10 AN Fittings (4) and Stainless Braided Lines (2) Remote Oil Filter Base High Quality Oil Filter All Fittings and Hardware Engine Mounts & Transmission Mounts CAD/CAM Designed CNC Machined Solid 6061 T-6 Aluminum Mounts Custom Urethane Bushings with True Isolation High Grade Hardware Kit Proper Engine Placement and Axle Alignment Lifetime Warranty on Engine Mounts Trans Mount CAD/CAM Designed CNC Bent Steel Mount Bracket Urethane Bushing High Grade Hardware Kit Designed for use with the T56 or T56 Magnum Lifetime Warranty on Transmission Mount Driveshaft aluminum One Piece Driveshaft with High Strength 1310 U-joints Designed for Use with the T56 or 4l60e Transmission retail is $1750 not including shipping and not including the aluminum driveshaft asking $1350 I will throw the 240sx LSx Master Cylinder Conversion Kit for $150 kit is used but in very good conditions. New unused wiring specialty harness for a 95 240sx pro series with converter box and all extra connectors and $600 new wiring specialty coil pack harness- SOLD oem gm corvette fuel filter and an adapters and 20 ft of tpf lines -$150 new Sikky front sway bar new in the box -$275 Ls ecu with Hp tunners and all shit removed - $250 thats all for now |
