![]() Join Date: Nov 2005
Tremec TKX conversions
If you aren't aware, Tremec just released it's TKX transmission, which is the evolution of the T-5/TKO500/TKO600 line. It now has triple cone synchros and a stiffer case, extending the usable shift RPM to 8000. This seems very promising as a no-compromise strong 5-speed box.
https://www.tremec.com/menu.php?m=183 ![]() Let's list some advantages here: 1. Lighter than a Z33/T56 box by 30lbs 2. Rated for 600lb-ft of torque 3. Massive aftermarket support 4. Available basically everywhere 5. Will be in production/service for years 6. Removable bellhousing 7. Mechanical or electronic speedometer drive 8. Compact 9. Shares bellhousing pattern with G-force dogboxes/others 10. Close ratio gearset Adapting these should be relatively easy, with an adapter plate and a bellhousing from your preferred engine (auto SR/KA/RB, R154 JZ), a custom pilot bushing and a 26-spline clutch disk in your required diameter. Here is a example of a G-force GSR to SR20 adapter: ![]() I do believe they would need an extended shifter based on how the TKO fits in an S13: ![]() Retail is $2,795 for the gearbox. Anyone else think this sounds pretty good? I think it's something to talk about at least.
Build: http://zilvia.net/f/showthread.php?t=643065 Friends don't let friends buy knock-offs. Last edited by PoorMans180SX; 11-11-2020 at 11:05 AM.. |
