Old 05-17-2005, 03:28 PM   #1
snp_ethan
snp_ethan is an unknown quantity at this point
Send a message via AIM to snp_ethan
help, removing shock without removing wheel
is it possible?
I've searched the forums, I got a cracked lug nut, a misthreaded lug bolt and only two nuts holding my pass front rim(4lug)... S14, zenki ...
I searched and found no specifics on how to do it.
if anybody could gimme a hand, that would be awesome
BTW, it all started with this very same problem(even same freakin nuts)
http://www.zilvia.net/f/showthread.php?t=68778
by the way, just skim through the thread im making reference on , so that you ll understand whats going on... in further detail...
snp_ethan is offline   Reply With Quote
Old 05-17-2005, 03:44 PM   #2
uno
uno is an unknown quantity at this point
Send a message via ICQ to uno
you can the rears but not the fronts
CA18DET t25, 440CC injectors, Greddy FMIC, Greddy Hot Pipe, Greddy Type RS Bov ,Greddy Turbo Outlet, Trust DP, Motoria 3" Catback , XS Tubular Manifold, Nismo AFPR ,Nismo Engine and Transmission Mounts ,Apex'i SAFC 2 Walbro 255lph, LSD, SPL Subframe Collars, Tein S Tech Springs, Tein Tie Rods, Upper Front and Rear Strut Tower Braces. Black 180sx wheels.
uno is offline   Reply With Quote
Old 05-17-2005, 03:48 PM   #3
orion::S14
orion::S14's Avatar
orion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud of
Drill out the lugs...replace the studs/nuts.
Then swap the shock.
- Brian
www.KA24DEvelopment.com
orion::S14 is offline   Reply With Quote
Old 05-17-2005, 03:51 PM   #4
snp_ethan
how do i drill them out tho? so, I just stick a srill whre the nut is suppossed to be and destroy wahtever is left of it?
Old 05-17-2005, 03:53 PM   #5
uno
pretty much
a carbide tip on a high power drill should take care of it. Then get real lug nuts hehe sorry that happened to you, that's a pain in the arse.
Old 05-17-2005, 03:57 PM   #6
snp_ethan
do you guys know how long it could takE? cuz honestly i have never even changed the pads on her, so I really wanna do this right...
Old 05-17-2005, 03:58 PM   #7
uno
just take your time and be careful. wear eye protection and try not to get into your rim and mess it up with the drill. Might take an hour or two to get them out.
Old 05-17-2005, 04:01 PM   #8
snp_ethan
dang.. ill try that... thanks..
Old 05-17-2005, 04:07 PM   #9
the head
the head's Avatar
the head is making a name for him/her selfthe head is making a name for him/her self
you could take off the front suspension as an assembly remove the three top nuts the swaybar endlink the lower control arm at the frame disconnect teh brake line and tie rod and remove the whole strut/spindle/LCA assembly at once
I never knew you could do that with an eggplant
the head is offline   Reply With Quote
Old 05-17-2005, 04:09 PM   #10
drew935
drew935's Avatar
drew935 is making a name for him/her selfdrew935 is making a name for him/her selfdrew935 is making a name for him/her self
snp_ethan take a pic of the lugnut or what's left of it. That should help us get a better visual.
I'm driving fast
-drew
drew935 is offline   Reply With Quote
Old 05-18-2005, 08:36 AM   #11
minhbestunnin
minhbestunnin is an unknown quantity at this point
i lowered an eclipes without taking the wheels off
minhbestunnin is offline   Reply With Quote
Old 05-18-2005, 08:38 AM   #12
uno
shocks are setup different on an s13 and an eclipse then. Eclipses probably have that fork like civics have.
Old 05-18-2005, 10:29 AM   #13
drew935
drew935's Avatar
no eclipse have a very close setup like our cars...
I'm driving fast
-drew
Old 05-18-2005, 10:32 AM   #14
uno
that's cool, you'd have to have the car very high and tilt the brake assembly a long way i would think on an s13 to get the shock out. plus getting to the bolts and reaching around the tire to do it would suck lol
Old 05-18-2005, 11:50 AM   #15
drew935
drew935's Avatar
yup that's regardless of what car it is. It sucks
I'm driving fast
-drew
Old 05-18-2005, 11:54 AM   #16
snp_ethan
ok... about th eclipse. I really didnt know that, but really doesnt interest me... as for the car, yeah sorry, its a zenki, running on Tein Flex Ill post pix ofr what I have left... I should be able to do it by today..
Old 05-18-2005, 05:49 PM   #17
snp_ethan
picx posted.. please help me out
Old 05-19-2005, 12:41 AM   #18
snp_ethan
any other suggestions besides drilling in?
Old 05-19-2005, 10:16 AM   #19
projectRDM
projectRDM's Avatar
Christ man, with all this crying going on you could have already gotten it out. Take a drill bit slightly larger than the nut and start drilling, you've got enough of a shank to hold it and the nut is cheap enough to break apart so you'll have it ground down to nothing in no time. That is the best and easiest solution. It's not going to come off by continually asking questions about it.
FORMERLY R240NA
Old 05-19-2005, 12:23 PM   #20
the head
the head's Avatar
Cold chisel and a hammer will work but you need to be careful not to hurt your wheels.
Old 05-19-2005, 04:36 PM   #21
ayes
ayes is an unknown quantity at this point
you could do it with a lift, but i dunno how far the brake/tire will angle down after the 2 bolts are off the shock
ninja vanish
ayes is offline   Reply With Quote
Old 05-20-2005, 01:53 AM   #22
snp_ethan
r240na. ease up dude, im just asking questions.. thats what forums are for right?
Old 05-20-2005, 06:35 AM   #23
Rennen
Rennen's Avatar
Rennen will become famous soon enoughRennen will become famous soon enoughRennen will become famous soon enough
Just drill it out or hammer a socket around the outside to break the lug stud... its simple.
I had the same thing happen to me last weekend. Make sure you get good drill bits and have a chorded drill (cordless' battery will die a few times).
-Matt
'89 Nissan 240SX fastback: #23 DSP/RallyMod2/Track Slut
'95 BMW 540i 6 speed: Ultimate Commuting Machine
PFM Racing
www.solo2.org
www.midwest240sx.com
Rennen is offline   Reply With Quote
Old 05-20-2005, 05:27 PM   #24
Dream240
Dream240's Avatar
Dream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond repute
On the cracked lug, just whack it with a hammer until it breaks completely off. With the stripped one, you have to break off the lug/stud. To do this just put your breaker bar on the lug and kick the breaker bar until it breaks off the lug. You'll have a busted stud which you'll have to get replaced but at least it's fixed.
Also you should NEVER drive around with only 2 lugs holding your wheel on!! Are you trying to kill yourself?
Don't mess with my monkey...he's loaded.
Dream240 is offline   Reply With Quote
Old 05-21-2005, 08:14 AM   #25
zeek
zeek is an unknown quantity at this point
do it right get jackstands and take the wheel off. Your wasting your time if you try to do stuff with the wheels on.
zeek is offline   Reply With Quote
