Old 12-04-2007, 01:32 PM   #1
sr20detconv
sr20detconv is making a name for him/her selfsr20detconv is making a name for him/her selfsr20detconv is making a name for him/her self
What supporting mods
Hi.
I have an 1989 and I'm swapping from CA18DET to SR20DET. Right now I have my engine set and it has an T28 on it.
I wanted to get out the most of my T28 and possibly changing to an GT28RS in the future.I want a reliable engine because it is my daily driver.
So here the mods I will put.
FMIC
Full exhaust(except dump pipe)
Walbro 255lph
Fuel regulator
clutch(maybe exedy stage2)
injectors
N62 maf
ECU Tune
t28(looking for 14psi approx)
RAS
My questions are:
-Do I really need an metal headgasket
-why is almost everyone using 550cc injectors when 650cc are almost the same price.
-Should I really use RAS
-what regulator should I use(I was thinking about the Nismo one)
-Are DeatschWerks Injectors good?
-I will only get my ECU shipped. Is the safc2(for exemple) an obligation?
sr20detconv is offline   Reply With Quote
Old 12-04-2007, 01:43 PM   #2
Slidin240Wayz
Slidin240Wayz's Avatar
Mother of shit.
Are you serious?
Old 12-04-2007, 01:46 PM   #3
jspaeth
jspaeth's Avatar
"-I will only get my ECU shipped. Is the safc2(for exemple) an obligation?"
what does that even mean
Daily driven
Old 12-04-2007, 01:52 PM   #4
sr20detconv
sorry for my bad english.I want to tune my ECU without the need of an SAFC2. Can I do this?
Old 12-04-2007, 02:03 PM   #5
slothonaleash
slothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond repute
yes....but instead you'll need an emanage, aem ems, megasquirt etc.... safc2's aren't the only tuning devices out there, but you will want a tune
i'm confuzzled
slothonaleash is offline   Reply With Quote
Old 12-04-2007, 02:18 PM   #6
Irukandji
You mean you're getting it reflashed? Like a rom tune? In that case, you can toss the SAFC in the trash where it belongs.
I've heard mixed things about RAS, it's on here somewhere, look for it.
Deatchewerks injectors are decent, but I know a few people who blew their motors when the injectors got stuck open.
People get 550's because they're more common ( a lot of different companies make them), and don't really need 650's. 550's is usually enough for most of us.
Old 12-04-2007, 02:20 PM   #7
statik
statik's Avatar
statik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond repute
Send a message via AIM to statik Send a message via MSN to statik
I wouldn't be so quick about ditching the afc, rom tunes aren't always perfect
97 240sx esaarr | Current Status: SOLD
statik is offline   Reply With Quote
Old 12-04-2007, 06:42 PM   #8
Neejay
Neejay's Avatar
Neejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfection
Yeah, if you already have it, might as well keep it for possible fine tuning.
Neejay is offline   Reply With Quote
Old 12-04-2007, 11:10 PM   #9
eastcoastS14
eastcoastS14's Avatar
metal HG is a must for certain power levels....if you're going for 350+ id do it
eastcoastS14 is offline   Reply With Quote
Old 12-05-2007, 12:59 PM   #10
djcobra
djcobra's Avatar
djcobra is making a name for him/her selfdjcobra is making a name for him/her selfdjcobra is making a name for him/her self
Hey sr20detconv,
If you want good set of injectors then stick with quality parts, such as: Tomei/Nismo, Sard, HKS/Denso etc... Last thing you want is a freaking injector failing or getting stuck and ka-boom, engine go bye bye... I have a set of HKS 555 injectors on mine, good enough for 330~350whp if that...
Also if you want full control of your car get standalone, ie, Power FC, HKS F-Con V Pro and many other standalones (yes it will cost more but better in the long run) won't limit you in the future when changing to different turbo's or injectors, cams etc...
Alot of guys on here including me have gone with metal head gaskets when changing cams/valve springs, or even re-building the bottom end etc.., some haven't and claim to boost the crap out of their stock SR (and i'm talking in the 20psi+ range), to me thats a ticking bomb ready to go ka-boom. If you want something reliable then build it right. If you're not going over the 300whp number then stock head gasket should be fine, keep an eye on boost. Others on here have done more with stock head gasket. Everyone has their own opinions.
I don't have anything fancy on my SR I just want reliablity, check the url below:
http://www.zilvia.net/f/showthread.php?t=161908
Even ask Statik, I believe he has a GT28RS pushing out 330whp with enthalpy tune (good stuff).
Steve O.
djcobra is offline   Reply With Quote
Old 12-05-2007, 01:18 PM   #11
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
You want reliable, do it right, Power FC tuned right. Its steep initially but it will save your ass in the long run. Injectors, pretty hit it on the dot, 550s are alot more common that 600-700cc injectors. Next common sizing for SRs after the 550s are the nismo/tomei 740s. Personally, get the 740s since your planning on going for a bigger turbo. You can never have too much fuel, as long as its tuned right. Headgasket, its one of those things that you cant tell how old the one thats in the engine till it blows, change it for a metal one for the peace of mind. Quality = Apex'i metal HG. Rocker Arm Stoppers is a must. Stock head is pretty trippy in a way that if you misshift at high RPM, your engine could impress you with its disappearing valve trick.
CLICK HERE!!!
Old 12-05-2007, 03:18 PM   #12
steve shadows
steve shadows's Avatar
My questions are:
-Do I really need an metal headgasket Metal Head Gaskets are normally installed wrong so don't use it unless your going for 20-30 psi of boost all the fucking time.
-why is almost everyone using 550cc injectors when 650cc are almost the same price. I dont know Maybe because the AFC won't control more than that size on ratio
-Should I really use RAS If you want to bounce off the rev limiter yes
-Are DeatschWerks Injectors good? Eh
-I will only get my ECU shipped. Is the safc2(for exemple) an obligation?Contact www.rs-enthalpy.com immediately
start saving your money
Like Me on FaceBook !
Old 12-05-2007, 04:24 PM   #13
sr20detconv
I'm on a student budget. I don't want to throw money where it is not necesary.I will stay with my OEM hg because I heard it's a pain in the a$$ to change the hg.
I want to know more about the destchwerk injectors because their is a sale at the moment on zilvia.
The block will remain stock. The engine had 165psi all around so I think it's in good shape.
Old 12-05-2007, 11:43 PM   #14
EAT Motorsports
EAT Motorsports's Avatar
EAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of light
Send a message via AIM to EAT Motorsports
ah 555cc injectors are plenty especially since you will most likely blow the headgasket if you need anything bigger than those... but you will not need the headgasket if your only running a t28.. also if your only going to run 14psi on a t28 you wont need most of what you listed if you are really on a budget...
EAT Motorsports is offline   Reply With Quote
Old 12-06-2007, 08:54 AM   #15
sr20detconv
what will I not need?Will a gt28rs max out the 550cc's?
I will put the RAS for peace of mind because I will drift my car.
I don't have the MAF on my engine so I will put a N62 for future mods. I'm on a tight budget but I don't want to spend the money on mafs 2 time or injectors.
Can someone give me feedback on the detshwerk injectors?
Old 12-06-2007, 11:19 PM   #16
sr20detconv
I need feedback on deatschwerk injectors please.
Old 12-06-2007, 11:33 PM   #17
EAT Motorsports
If you are really on a budget then stick with the stock injectors and only run 14 psi... untill you can afford some higher quality injectors....
Old 12-07-2007, 09:43 AM   #18
sr20detconv
14psi on a t28 and 370cc?Are you sure it's safe?What injectors do you recommend?
Old 12-07-2007, 12:02 PM   #19
i need tires
i need tires's Avatar
i need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to all
Send a message via AIM to i need tires
here is what you need to get the numbers you are shooting for:
this pull was on 18psi
completely stock redtop sr
gt2871r .64ar
sard 550cc
n62 maf
91 octane mixed with 5gals of 100 (full tank of gas)
CGTuning ECU (tuner here in Arizona)
fmic
3" straight pipe
AFR were around 11.5 under boost
now for the dyno charts!
the stuttering at the top is the clutch slipping. shitty clutch for the HP he has haha
JadeCantDrift Blogspot
i need tires is offline   Reply With Quote
Old 12-07-2007, 01:11 PM   #20
sr20detconv
nice to see that 550cc is enough for 330whp. I thought I needed bigger than 550cc to reach that power.
Still need info on that deastchwerk injectors. Might buy them soon.
Old 12-07-2007, 01:14 PM   #21
i need tires
like other people have said they have been known to stick open
i would go with SARD, NISMO, or like im doing OEM sti 02-04 inj
Old 12-07-2007, 02:27 PM   #22
statik
statik's Avatar
gt2871r .64ar
sard 550cc
n62 maf
fmic
3" straight pipe
That slipping clutch gave you a good 30whp, nice
Old 12-07-2007, 02:29 PM   #23
i need tires
haha imagine if it wasnt slipping!
Old 12-07-2007, 02:30 PM   #24
statik
statik's Avatar
eh, you won't make much without cams even with that turbo, stock cams need to go around 300+, id be surprised if you actually hit 330 with that setup
Old 12-07-2007, 03:05 PM   #25
i need tires
umm the chart shows 331whp....
