Old 02-13-2009, 06:23 PM   #871
IDRFT95S14
IDRFT95S14's Avatar
IDRFT95S14 is an unknown quantity at this point
A nice piece of amazing work,cant wait to see it finished
IDRFT95S14 is offline
Old 02-13-2009, 06:35 PM   #872
fcf sil80
fcf sil80's Avatar
fcf sil80 is on a distinguished road
this car is f-n insane mad props to you man cant wait to see the finished product..
fcf sil80 is offline
Old 02-14-2009, 01:15 PM   #873
wgJoY
wgJoY's Avatar
wgJoY is an unknown quantity at this point
Send a message via AIM to wgJoY
ughhh daaaamn. I was reading through all of this, and hoped that I would see this car built before i reached the end >.<
great attention to detail, amazing car!
wgJoY is offline
Old 02-16-2009, 10:15 PM   #874
CursedGTR
CursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfection
Originally Posted by SuperiorS14 View Post
how bout a hollinger or hks sequential transmission???
Holinger = 20K plus 5K for each rebuild after every 5K miles. Ummmmmm No.
HKS Doesn't make a sequential for the RB26 but their early model boxes are decent as they were made by holinger. Can usualy find one for around 3-5K and a friend of mine just did a how to and how to rebuild them so price is right at the right time and I might buy one of those.
I am going to shelf the transmission for now and do more research.
I Am thinking that Jericho might be a good choice.
GForce GF5R (GTR-700 uses one) might be a good choice
Also the Cross Mission is out. Too many friends of mine are popping them even after treatments over here.
If I can get these guys here in Okinawa to part with the OS88 they had promised me a while back, I will definitely get it, but they are backing out as of right now.
Update:
I decided to do wheel tubs and ditch all fo the fiberglass crap. Thanks to the guys in the fabrication thread for pointing me int he right direction. I Got most of the drivers side tub done this weekend. I still need to trim it up, grind a little, add a couple more welds and do some bondo work but all that is only a days worth the work anyways. Here are the pics. When it is all done everything will be nice and smooth without a metric shit ton of fiber, bondo, filler and other crap. The passenger side will be a little different as I will weld in joiner pipes for the intercooler piping and a couple other things, but all will pretty much be same same and hopefully all finished up by Sunday.
CursedGTR is offline
Old 02-16-2009, 10:19 PM   #875
ReDs13SiLvIa
ReDs13SiLvIa's Avatar
ReDs13SiLvIa is an unknown quantity at this point
Good luck on the build...
ReDs13SiLvIa is offline
Old 02-16-2009, 11:29 PM   #876
jspec240
jspec240's Avatar
jspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfection
haha I knew I sucribed to this thread for a reason.. IT JUST KEEPS GETTING BETTER!!!
Awesome job bro Im in the process also. hope you have some paint left over... lol
DREW
SLIDE TO SIDE WORLD WIDE
Feedback!! http://www.zilvia.net/f/showthread.php?t=182673
661 sliders Gymkhana @ buttonwillow
http://zilvia.net/f/south-western-st...-sessions.html
>> Bakersfield Hook up thread <<
jspec240 is offline
Old 02-16-2009, 11:34 PM   #877
onepuff
onepuff's Avatar
onepuff is on the path to ruinonepuff is on the path to ruinonepuff is on the path to ruin
Nice job as always! I see you went all the way down to the frame rail. Did you put sheet on both sides like the factory or just one piece on the engine side? Or did you just use slightly thicker material? I need to take my tubs all the way down to the rail when i do mine so was just wondering how you did it.
onepuff is offline
Old 02-17-2009, 12:03 AM   #878
CursedGTR
I left a little bit of the original metal vertical from the frame rail for me to weld to (About 2 inches). I also used 1.2mm sheet metal which is a little thicker than original. Littel bit of a bitch to work with but it is sturdy. Make sure you leve some tabs of stock metal to weld to all the way around. The fab thread in the tech section answered my questions with a shit load of pictures and how to's so you should look int hat thread before you do too much.
Old 02-17-2009, 12:23 AM   #879
onepuff
onepuff's Avatar
Cool thanks. I've been following that thread. It's gotten kinda big with some great work. I'll have a look through again.
onepuff is offline
Old 02-17-2009, 12:57 AM   #880
C. Senor
C. Senor's Avatar
C. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfection
Send a message via AIM to C. Senor
good lord. i just read the whole thing from page 1. this is a freaking awesome build. it's definitely one of the best i've ever seen.
Don't forget to tell your mom, she ran out of eggs this morning!
C. Senor is offline
Old 02-18-2009, 08:38 AM   #881
IsBettyBish
IsBettyBish is an unknown quantity at this point
Option 4: Th400 or 4L80E Race prepped transmission with manual valve bodies, and proper stall converter.
Paddle shifter and call it a day. sounds like the best bang for buck to me with the power number requirement to match.
IsBettyBish is offline
Old 02-18-2009, 09:22 AM   #882
Syncade
Syncade is making his/her stupidity well-knownSyncade is making his/her stupidity well-knownSyncade is making his/her stupidity well-knownSyncade is making his/her stupidity well-known
Send a message via ICQ to Syncade
Thatd be boring
Jets > Cars
Syncade is offline
Old 02-18-2009, 09:30 AM   #883
Om1kron
Om1kron's Avatar
=) hehe you're welcome, i'm glad Jesse actually took pictures of him doing the process so I could re-post them on every forum he doesn't visit lol.
Wayne Edwards
https://om1kron.blogspot.com
Om1kron is offline
Old 02-19-2009, 04:24 AM   #884
CursedGTR
Can't deny the fact that people are putting 2000 HP through that solution with no problemand extremely consistent times as well. I will have to put alot of dedicated thought into my diff and tranny combo to make sure I get it right.
Old 02-19-2009, 05:04 AM   #885
SILVIA_KIDs14.5
SILVIA_KIDs14.5's Avatar
Trader Rating: (-1)
SILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choices
Feedback Score: -1 reviews
go wit ppg the quality second to none also parts for os gilken are a bitch to come by in the states some thing to remember if you come back this way
SILVIA_KIDs14.5 is offline
Old 02-19-2009, 08:30 AM   #886
VQMaxFan
VQMaxFan's Avatar
VQMaxFan is on a distinguished road
What kind of engine management are you going to use? If its aem ems can control the 4l80e so manual valve bodies really wouldn't be needed.
VQMaxFan is offline
Old 02-19-2009, 08:42 AM   #887
RX729
RX729's Avatar
RX729 is an unknown quantity at this point
Its gonna be beast once its done...!
RX729 is offline
Old 02-19-2009, 08:45 AM   #888
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
i don't generally like tubby girls, but your tubs are hot!!!
awesome work, i aspire to be like you when i get over my "do it wrong first then do it right 2nd" phase
clark is offline
Old 02-19-2009, 11:55 PM   #889
SlideAlliance
SlideAlliance's Avatar
SlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond repute
I do it right the first time, then get bored and do it right but differently two more times
Battle Idol Works 2015
SlideAlliance is offline
Old 03-07-2009, 09:44 PM   #890
CursedGTR
Got the Wheel tubs all set up and Bondo laid down. I will sand the shit out of it over the few days and then repaint the engine bay. Looks Like I might actually be on schedule kind of sort of with this one. I did not take pictures yet, but I used Body Caulk and sealed up all of the seams within the wells themselves to prevent rust and will go ahead do undercoating as soon as everything is complete.
Also, I am working possibly getting a deal on a HKS Dog box with modified transfer and triple plate clutch. If it goes through, the transmission issue is solved.
Old 03-07-2009, 09:58 PM   #891
DeadlyZ33
DeadlyZ33 is just really niceDeadlyZ33 is just really niceDeadlyZ33 is just really niceDeadlyZ33 is just really niceDeadlyZ33 is just really niceDeadlyZ33 is just really niceDeadlyZ33 is just really niceDeadlyZ33 is just really niceDeadlyZ33 is just really nice
Always good to see progress on this car.
DeadlyZ33 is offline
Old 03-15-2009, 01:27 AM   #892
CursedGTR
Wheel Tubs are ready for some paint. A little wet sanding throughout the engine bay and I am good to go for paint in about one week. I also have to do body caulk between the core support and the tubs, although wleded in, I made it possible to replace the core support by using a drill and a grinder to remove it. The body caulk will help keep crap and wet shit out of there.
Originally I was going to 70mm - 80mm transition/joiner pipes welded into the new sheet metal for the intercooler piping on the hot side to connect to, but I discovered that the size is a little too much and would interfere with the frame rail, so Now I am going to either make a 70mm oval slot or two 80mm holes, just haven't decided yet, but then again, I don't need to any time soon.
I used black paintable body caulk to seal up all of the seams inside of the wheel well, next I will hit it up with some undercoating and call it finished under there.
Old 03-15-2009, 01:53 AM   #893
zorak
zorak's Avatar
zorak is an unknown quantity at this point
Send a message via AIM to zorak
ummmm tubby.
zorak is offline
Old 03-15-2009, 02:40 AM   #894
Slideways^Jordan
Slideways^Jordan's Avatar
Slideways^Jordan is an unknown quantity at this point
Send a message via AIM to Slideways^Jordan Send a message via Yahoo to Slideways^Jordan
I just got done reading through all 30 pages and man this is by far the best build i have ever seen, my hats off to you sir!
Slideways^Jordan is offline
Old 03-15-2009, 02:59 AM   #895
GSXRJJordan
GSXRJJordan's Avatar
Great job on the tubs! After just doing this myself, I can say that yours are probably the perfect size. Bondo helps with the look soooooo much.
GSXRJJordan is offline
Old 03-15-2009, 03:32 AM   #896
gotspins13
gotspins13's Avatar
gotspins13 is an unknown quantity at this point
Send a message via Yahoo to gotspins13
omg just went through alll the 30 pages of this and like everyone else said amazing build, but damn its almost been 2 years!!! cait want to see it on the streets=]
perfectly said! FJ20ET 16 valve - the holy grail of Nissan engines
gotspins13 is offline
Old 03-15-2009, 04:19 AM   #897
CursedGTR
YEah it has been a while, but it takes time to sock away the money for all of these nice parts too. Should only be another year or so. Chasis is done after the engine bay paint, but then I have to come up with cash for EMS, Seats, Mission, Proper Rear end and some pipes along wiht all of the little shit that is going to come up. Would be alot closer in the next 2 months but paying for shipping is going to cost some dough.
Old 03-16-2009, 01:46 AM   #898
blu808
blu808's Avatar
blu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfection
Send a message via AIM to blu808
Can I come hang out with you in Japan?
You are the f man.
blu808 is offline
Old 03-16-2009, 02:46 AM   #899
SlideAlliance
Come home already. lol
Old 03-16-2009, 03:49 AM   #900
gotspins13
gotspins13's Avatar
oh i see well so fas looks totally crazy im sure you got alot of other cars beat by farrrrrrrrrrrr
and ya i totally forgot about the whole money and saving thing! haha i guess i got cought up in the build and pics that i thought you had it all already and were putting it together but i was mistaken=]
so after its all finished and you come back to the us, your bringing this piece of beauty with you right?!
