Old 08-22-2007, 09:05 PM   #1
bardabe
bardabe's Avatar
Oil Cooler Set up
Alright, I know this is stupid but whatever, I got an OIl Cooler
I got 1 Oil Cooler
4 1/2npt to AN-8 Adaptors
4 AN -8 fittings
Oil Filter Sandwich plate
you guys think I will be ok with that?.
i did a search but i couldn;t really get my queston answered so yeah just wanna make sure before I put it on my car last thing I want is my Shit blowing up and spilling oil all over the highway lol
-Juan
p.S. No I don't want to relocate my oil filter it's perfectly fine where it is now.
Review Thread
bardabe is offline   Reply With Quote
Old 08-22-2007, 10:36 PM   #2
bardabe
bardabe's Avatar
Ok Updated / relooked my set up. this is what i want to run you guys think it's Ideal?
Review Thread
Old 08-22-2007, 11:03 PM   #3
MavericStephenc
MavericStephenc's Avatar
MavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfection
Send a message via AIM to MavericStephenc
juan greddy makes sandwich adapter plates, I think spl carries them too........why didnt i just im you
MavericStephenc is offline   Reply With Quote
Old 08-22-2007, 11:35 PM   #4
bardabe
bardabe's Avatar
+1 for you buddy found it
http://www.pegasusautoracing.com/pro...asp?RecId=5128
Review Thread
Old 08-23-2007, 12:06 AM   #5
GSXRJJordan
GSXRJJordan's Avatar
what motor is that for Juan? I was thinking about doing an oil cooler setup, based on the Trans Dapt 1113 Remote Oil filter kit (it fits S13 SR's and KA's I think - http://www.jegs.com/webapp/wcs/store...10002_42218_-1) and just rerouting one of the hoses to the cooler... keeps the cost down
Old 08-23-2007, 12:36 AM   #6
atom
atom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to all
Seems pretty standard but you're missing a thermostat. I have the same sandwich plate from that link to pegasus except I got it from Canton. It's a nice piece but I have to do run an in-line thermostat. Mocal makes a nice sandwich plate with an integrated thermostat.
http://www.racerpartswholesale.com/mocal.htm
atom is offline   Reply With Quote
Old 08-23-2007, 01:30 AM   #7
MavericStephenc
the greddy one i suggested has a thermo http://240sxmotoring.com/groilcoadw.html
Old 08-23-2007, 01:48 AM   #8
johngriff
johngriff's Avatar
I don't like the -8 for oil, especially the rb, I would want to go -10 at least.
[email protected]
Old 08-23-2007, 03:10 AM   #9
MrChow
MrChow's Avatar
MrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant future
Send a message via AIM to MrChow
I believe Juan as a RB20.
Yeah your oil is in a great spot!
Originally Posted by TheSquidd View Post
Are you the guys that buy your KSports and just turn the dampening knob to 32?
"It's stiff and hurts my livers! I'M A HANDLING GOD!"
WTT: 2 way for 1.5 way LSD
MrChow is offline   Reply With Quote
Old 08-23-2007, 09:20 AM   #10
Sir
Sir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud of
I've seen someone else post that as well. Is there some kind of reasoning behind it?
My current setup is all -8 with a 10x10 Setrab oil cooler
Originally Posted by drift freaq View Post
I suggest you shut the fuck up.
Sir is offline   Reply With Quote
Old 08-23-2007, 12:18 PM   #11
bardabe
bardabe's Avatar
yeah but if you do that then you will have to get 1 extra hose (maby 2 becuse of length) an inline thermostat, an Oil cooler, and fittings. wich will probably add up to more. im sure it will
yeah I just thought about that, and am looking into it.
ha ha 5$ more cause it's greedy I'm thinking about it lol
Yeah is there any reason behind that? what really are the benefits of tunning that big ass line? the 1/2 to 8AN is exactly the same inner diameter as the fittings on the block. so wouldn't going from a small hole to a bigger hole be like a restriction?
yep yep, so is the Plug on the oil pan, I don't have to ever jack up my car for an oil change, Slide the pan under the car, then lean in take the plug off from the top drain oil, then reach for the filter all from the top =)
yeah I mean my engine is only a 2.0 the Greddy oil relocation kit my friend has on his SR is running -8AN from greddy (the size of the line) and so is the one on my friend's KA. that's whay I leaned in towards -8AN. that's also what my nascar buddies said. -8AN is perfect for oil, same size we run on the Nascars.
so I will like to hear why the -10 is Preferable over the -8AN aside from the ovious Allot bigger diameter.
Review Thread
Old 08-23-2007, 12:21 PM   #12
Dousan_PG
Dousan_PG's Avatar
most all the kits that come from japan (greddy, tomei block, um...who else...section i think) are -10
everyone i know who did them said go -10
so i went -10
-8 should be fine
but i prefer -10
and its fine
i got a new oil pump anyways so no worries.
Aaron
Pink GodziRa
Old 08-23-2007, 12:43 PM   #13
mehsilvia
mehsilvia's Avatar
Trader Rating: (39)
mehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfection
Feedback Score: 39 reviews
Lots of great info, and in time. I too am in process of running a relo/cooler setup.
Question tho - its not clear how the external thermo is run with the setup. Can anyone do a quick illustration of how that is connected?
mehsilvia is offline   Reply With Quote
Old 08-23-2007, 12:47 PM   #14
Slidin240Wayz
Slidin240Wayz's Avatar
Just get the greddy sandwich...built in thermo.
Set!
Slidin240Wayz is offline   Reply With Quote
Old 08-23-2007, 01:23 PM   #15
mehsilvia
mehsilvia's Avatar
Trader Rating: (39)
I would have, but have a brand new Greddy Relo kit sitting here right next to my B&M Oil cooler. Was just making up the stainless -10an lines and looking at how to run everything together. While doing so i was searching around about details and came across this and a few other websites mentioning the thermostat.
Just not clear to me with having 4 NPT connections on the external, how it is all put together.
Old 08-23-2007, 01:52 PM   #16
atom
Instead of plugging the inlet and outlet hoses to the oil cooler, you plug them into the thermo instead. Now you need two extra hoses to run from the thermo to the oil cooler itself. So basically you need 4 extra fittings and two more lengths of hose (or if you already have two measured lengths of hose you can cut those into 4 pieces obviously) compared to an install with no inline thermostat.
Old 08-23-2007, 01:53 PM   #17
Sir
FYI don't use this style spin on block
http://personal.linkline.com/dbarton...erAdapter1.jpg
it will get loose and start to leak.
Mehsilvia - oilcoolers and blocks usually have female ports (1/2NPT) that you use the 1/2NPT-xAN adapters to attach your lines to.
Oilcooler NPT <-> NPTtoAN adapoter <-> AN fitting-AN line-AN fitting <-> ANtoNPT adapter <-> Oil block.
Old 08-23-2007, 02:09 PM   #18
mehsilvia
mehsilvia's Avatar
Trader Rating: (39)
Thank you gentlemen.
Old 08-23-2007, 11:33 PM   #19
ch1873857
ch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the rough
Send a message via AIM to ch1873857
the cooler i just picked up doesnt have a thermo. i know what it does but if i dont have one what precautions should i take. say let the car warm up more before driving? btw its a 13x6 cooler with 10an hoses/fittings. which are freakin huge, they are 7/8" inch thick.. thanks guys.
ch1873857 is offline   Reply With Quote
Old 08-24-2007, 01:40 AM   #20
GSXRJJordan
The common thought is that the oil takes a while to warm up anyway (longer than your coolant, for sure) so when you basically double your oil volume (with the cooler/lines/etc) it'll take EVEN LONGER to warm up. Sure, you might be OK without a thermo, but then again, what's $100 when you're talking about rod bearings?
Get that thermo listed above and a couple more hoses. That's what I plan on doing ~ It'll buy you peace of mind.
Old 08-24-2007, 01:43 AM   #21
Dousan_PG
Dousan_PG's Avatar
i run no thermo
and my stuff is fine
full track car
warms up real fast
let ti idle, drive it around. get the temps up, then rip on it
for a street car. i would probaly run a thermo
but maybe not.
Aaron
Pink GodziRa
Old 08-24-2007, 08:29 AM   #22
mehsilvia
mehsilvia's Avatar
Trader Rating: (39)
Originally Posted by Dousan_PG View Post
i run no thermo
full track car
warms up real fast
but maybe not.
Now thats what i was thinking. Considering mine is also track purpose. Hmm . . . decisions.
Old 08-24-2007, 09:18 AM   #23
ch1873857
thanks guys. i like that ,"track car. warms up real fast" i may, down the road pick up on of those inline ones.
Old 08-24-2007, 07:32 PM   #24
reflexdb
reflexdb's Avatar
reflexdb is making a name for him/her selfreflexdb is making a name for him/her selfreflexdb is making a name for him/her self
Send a message via AIM to reflexdb
Well, nascars also use six stage scavenge pumps:
http://daileyengineering.com/SMALLSIZE.htm
Check out the link. I can believe that the scavenge lines are -8, but the single line from scavenge pump to reservoir is -20 (that's f_ing big). Point is, bigger isn't going to hurt you. I used -10 lines on the dry-sump I designed for our FSAE car, Honda 600cc F4i motor. Some other teams used -8, some used -10. The -10 are a little bit more bulky, but will not be a flow restriction as said above. Plus, looks like you have plenty of room.
reflexdb is offline   Reply With Quote
Old 08-24-2007, 08:13 PM   #25
hitman
hitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfection
Send a message via AIM to hitman
i ran -10 to compensate for my abnormally small penis
driftparty.com
hitman is offline   Reply With Quote
Old 08-24-2007, 08:21 PM   #26
johngriff
johngriff's Avatar
You need -12 to do that!
[email protected]
Old 08-24-2007, 09:44 PM   #27
Antihero983
Antihero983's Avatar
i know ebay shit is pretty shady most of the time, but what about this O.C. kit?
http://cgi.ebay.com/ebaymotors/PERFO...mZ250157586850
this would be for a autocross/street driven KA24DE N/A btw..
Old 08-25-2007, 12:24 AM   #28
bardabe
bardabe's Avatar
Something about "Glow Shift Gauges" making oil cooler kits dosent sound right. lol i wouldn't trust that shit. it;s like buying an APC Turbo kit. I wouldn't trust that shit either
Review Thread
Old 08-25-2007, 12:49 AM   #29
Irukandji
small penis? more like vagina
Irukandji is offline   Reply With Quote
Old 08-25-2007, 03:09 AM   #30
ch1873857
got one of these kits for free so i said fuck it why not. turned out to work really well. -10an hoses, 13x6.5 cooler, no leaks, all the fittings and your ports for pressure and temp. hell their customer service was pretty good. i was very skeptical, i thought it would be complete junk but hey, it works.
